Results 1 to 11 of 11
    Junior Member
    Oct 2015
    1
    Possible f😧😧cked Crankshaft
    Hi All,
    I've got a lot of grey/white smoke bellowing from my exhaust of a v70 1998 turbo when I drive.
    1 garage reckons the crankshaft could be damaged, what would be the cost of fixing this or would an engine swap be easier??
    Thanks In advance
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,529
    Sounds more like the turbo seals gone.
    310.2bhp / 333ft/lb
    VPCUK reigning car of the year
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    White grey smoke normally indicates worn turbo seal, I very much doubt it will be crankshaft.
    Now in an Audi...to allow more
    time for my 850s lol
    Shinsplintz 101's Avatar
    Nov 2013
    Baldock, Hertfordshire
    355
    If it's the crank it'll be knocking like a barsteward.
    As above, any smoke from the t5 lump is either worn turbo seals, valve stem seals or piston rings. Normally, but not always, in that order.
    Good luck. Cheers, Morgan
  5. #5
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,362
    I don't think I'd take it back to that garage if they said it was the crank.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  6. The Following User Says Thank You to claymore For This Useful Post:
    Biff (Sunday 14th August 2016)
  7. #6
    Trying to keep on top of it
    LeeT5's Avatar
    Oct 2004
    Kent
    992
    Crankshaft..
    Do what Claymore says and don't go back to that garage.
    Only time Crankshafts fail is normally due to the oil pump failing, which is not very common. Trust me when I say this......You'd definitely know if it were your Crank and or the oil pump failing. The noise would be horrendous mate!
    2004 V70R 6spd manual:: Custom JRtuning REMAP @ peak 21psi :: Custom 2.75" exhaust :: TTV SMF + 07 Clutch :: WG 5.0 psi :: Tints :: IPD R gauge Rev.3 :: CFWerks door pod :: Forge CBV + yellow spring :: Windowed stock housing + blue filter :: Powerflex :: Superpro Engine mount :: Brembo Dot 5.1 :: TW FMIC :: Eibach 5mm spacers :: Brembo 330mm drilled discs :: iMiV 'Classic'+ BT :: D2R XENARC 5500k + LED H7 + LED H3 :: VolvoTech CFE OBD-V1 :: See garage for full mod list
  8. #7
    Junior Member
    Oct 2015
    1
    Would it need stripping down to find the problem?
  9. #8
    Junior Member
    Oct 2015
    1
    It definitely isn't knocking, it just pimps a lot of grey/white smoke out in intervals.
    First of all a little smile, then it bellows out, then stops.
  10. #9
    LeeT5's Avatar
    Oct 2004
    Kent
    992
    Why strip it down? It's not your crank shaft mate, end of.
  11. #10
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,362
    you've got a knackered turbo
    PIC][/SIGPIC]
  12. #11
    A very bad whale
    Aug 2013
    1,261
    As above shagged cranks don't produce smoke, fubarred turbo oil seals do as do valve stem seals or oil rings, have a look in your turbo to intercooler pipe , if it's really oily it's probably the turbo , they are all a but oily by the way .
    Check the turbo for play too it's easy to feel if the bearings are cuffed. Do a compression test if you can , stick an endoscope down into a cylinder , you can get them for smartphones for a few quid these days.
    But deffo not your crank you would know believe me they make a hell of a racket and the car runs like a bag of spanners.
