Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 224
Thread: S70 r 1998
  1. #101
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Quote Originally Posted by Yosser View Post
    What's the plan replacing the injectors?
    To the best of my knowledge blues and whites flow exactly the same.
    Correct, Nick, same flow rate at 3 bar so no reason apart from having a spare set for less downtime on the car - it's my daily
    If I changed the FPR to 3.8 bar the blues can flow higher at about 395 cc/min but no plans to do that so far. The map/power level suits the car very well.
    Last couple of jobs before heading back to work
    Cleaning the bird ££££ off - never tried this before...wetting a cloth & laying it over the ££££e to soften it........and some locking bolts finally! I may regret this)
  2. #102
    The Volvo with a 'twist'!
    AcidicDavey's Avatar
    Mar 2012
    Hereford
    284
    Take that bolt out and put it in the spot opposite the valve then my OCD will be at peace
  3. The Following User Says Thank You to AcidicDavey For This Useful Post:
    jamesy12345 (Saturday 16th May 2015)
  4. #103
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by AcidicDavey View Post
    but how will the moose see it then??
  5. The Following User Says Thank You to jamesy12345 For This Useful Post:
    AcidicDavey (Saturday 16th May 2015)
  6. #104
    Mar 2012
    Hereford
    284
    I think he'd rather it in his antlers tbh
  7. #105
    Iraq Lobster
    May 2013
    4,606
    I'll do it before you see the car next time (unless I can't get them out or I forget )
  8. #106
    Iraq Lobster
    May 2013
    4,606
    Another couple of small jobs....about time for a new coil....
    And a starter motor relay.
  9. The Following User Says Thank You to jamesy12345 For This Useful Post:
    t5 pete (Monday 13th July 2015)
  10. #107
    A very bad whale
    Aug 2013
    1,261
    If you really have OCD you would describe it as CDO . That is in alphabetical order
  11. The Following User Says Thank You to Orca2 For This Useful Post:
    Hound (Wednesday 22nd July 2015)
  12. #108
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    I had to replace mine but had a good one in the spares shed how much are they new from volvo
  13. #109
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by t5 pete View Post
    with a little bit of discount that one was 105 quids plus VAT, Pete
  14. The Following User Says Thank You to jamesy12345 For This Useful Post:
  15. #110
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Good price and to think they lasted for 20yrs it's not much at all
  16. The Following User Says Thank You to t5 pete For This Useful Post:
    jamesy12345 (Tuesday 14th July 2015)
  17. #111
    Iraq Lobster
    May 2013
    4,606
    Small update - I seem to have fixed the 3CD changer using the method in the thread below.
    http://www.vpcuk.org/forums/showthre...ht=#post778355
    I put it all back together, code back into radio then went to start the car & got nothing - or a least ignition lights with no cranking. Starter relay was clicking but nothing doing. Relay was new btw as I had this fault briefly before and assumed I had fixed it...........like y'do.
    So, thinking that there was a dodgy connection somewhere I took off the feed to the boost gauge light, USB box thing and manual fan switch. I also re-made some cuts that had been made to the loom behind the radio....assuming for connecting aftermarket stuff...must remember to solder those & insulate again.
    Still nothing. Replaced all mentioned connections making sure they were as sound as possible & insulated. Supposed to be on the Eurostar in a few hours & still at the other end of the country.........DON'T PANIC...very quickly traced the fault to a dodgy connection on the back of the starter solenoid - the thin green/brown wire. I disconnected everything here and cleaned up with WD40 (or equivalent*). The green/brown wire multi-plug I tried to close up a little for a tighter fit and pushed the plug on/pulled it off several times to clean it up.
    Sorry for no photos it was all a bit rushed. But I am now about 500 miles up & no non-starts!
    *GT85. Other cheapo spray lubricants are also available from the Pound Shop.
  18. #112
    Iraq Lobster
    May 2013
    4,606
    Photo of the offending item mentioned in post #111.....no electricity 'through the wire' was the problem, said Kanye
    ..& shot of the average MPG after 1044 mile round trip. Maybe not very accurate but well over 30 I would think:
  19. #113
    Sep 2014
    1
    Woah! Your counter is very optimistic! Mines gone down to 25.6 as it's a weekend car
  20. #114
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by MaxTS View Post
    I didn't pay much attention to fuel stops, as soon as it was down to half a tank & spotted a Shell '98 Sans Plomb' sign I filled her up, no brim-to-brim checking. It was doing well over 200 miles for half a tank/approx. 3 hours driving hence the guess of 30+ mpg.
  21. #115
    Sep 2014
    1
    Sorry I was aiming at the car's counter, mine can get around 30 on runs
  22. #116
    Iraq Lobster
    May 2013
    4,606
    yes mate I understood, I don't believe it really does 36 mpg either 30 will do!
  23. #117
    Appreciative
    kmb's Avatar
    Oct 2014
    Suffolk & Rhone Alpes
    927
    I checked my 850 trip computer versus full tank method and it was found to overread mpg by 1mpg i.e. 32mpg on trip computer versus 31mpg calculated.
    Quite impressed with the accuracy to be honest.
  24. The Following 2 Users Say Thank You to kmb For This Useful Post:
    jamesy12345 (Thursday 23rd July 2015),MoleT-5R (Tuesday 21st July 2015)
  25. #118
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by jamesy12345 View Post
    Glad you got your wiring sorted and that not a bad average for an 'R' and probably at a fairly swift pace as well. Mine was returning approx 14.5 mpg on the way home from shakey with exhaust hanging off just tootling along....lol
  26. The Following User Says Thank You to MoleT-5R For This Useful Post:
  27. #119
    All the ladies love it
    sideways!
    Doingitsideways's Avatar
    Nov 2012
    Manchester
    2,186
    Ah, these MPG readings...
    Methinks noone's told the computer that the injectors have been changed?!
    I'd go along with Jamesy though, prob just a nudge over 30mpg, not bad going really for a 300 horse motor
  28. The Following 2 Users Say Thank You to Doingitsideways For This Useful Post:
    jamesy12345 (Thursday 23rd July 2015),LiamT4 (Wednesday 22nd July 2015)
  29. #120
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Erm can I have some of that read the S70r mpg tonight 19.6 which is a improvement over the 19.5 it said the other day looks like the other half likes the new found power
  30. The Following 2 Users Say Thank You to t5 pete For This Useful Post:
    jamesy12345 (Thursday 23rd July 2015),MoleT-5R (Thursday 23rd July 2015)
Tags for this Thread
