jamesy12345 (Tuesday 20th January 2015)
t5 pete (Tuesday 20th January 2015)
Car obviously looks great on both sets of wheels.
Personally prefer Satellites but in the proper Volvo T-5R Anthracite colour, bright silver is a bit much on a bright yellow car for me.
With them wheels in the grey colour it looks sort of original but with slightly different (and better) wheels
98 V70 AWD - Long Term Companion. Loads of little changes, the Volvo with a twist.
96 850 R Estate - Pink Pus, project pulled from the weeds!
Oh, plus a glorious (but dead) 01 Alfa 166 V6 and a 05 Liquid Yellow Clio 182.
Wow!dont mind admitting it but I've got a semi over this!!! Hahaha
t5 pete (Wednesday 21st January 2015)
claymore (Thursday 5th February 2015)
Had a few hours this morning on the car I've replaced all dash light bulbs that was shot,re aligned steering wheel as it was slightly off and cleared all the old codes which it had.
Here's the list
A2
233
535
414
233
535
A3
311
312
314
322
213
214
424
142
144
122
A7
122
113
132
B1
122
124
126
132
134
212
222
231
232
234
236
311
314
321
411
414
418
420
B2
122
B5
222
232
242
All cleared and came back with all 111 so will give the car a run for a while and see if any of them come back
jdavis (Sunday 8th February 2015),martin_r_smith (Sunday 8th February 2015)
That's the most impressive list of fault codes if ever seen mate!
854 T5 - The new project.
850 tdi - sorely missed.
t5 pete (Sunday 8th February 2015)
Started to fit the obd2 ports today
locate the 3 wires one for live one for earth and other k line to b36
port b36 marked
Now heres the problem the k like from the obd2 port actually splits into five lines but in the threads and write ups it just says to connect it to the b36 pin.
You could have 'ad me old one- and the airbox too. Yes it is a 3 inch MAF.
I am also slightly bothered that your new shiny MAF housing has the MAF sensor orientated perpendicular to the flow?
Volvo ABS ECU Repair
Never noticed that dave tbh ill have to have a look at an original one and see as it may cause problems.
If it does ill either have to get another one or add a bit on so it can be bolted other way round
I have a brand new MAF housing from an late R if you want it Pete?
Not sure on diameter....I'll measure it and come back.
t5 pete (Monday 9th February 2015)
But Mr Wobbles one does look to be fitted 90 degrees out to standard, is me7 different ???
just braved the cold to check and they changed it at me7 and rotated the maf base 90 degrees, never noticed it before, well spotted Dave, but Pete should be ok with and 850 style maf
t5 pete (Monday 9th February 2015),Wobbly Dave (Monday 9th February 2015)
Yep beat me to it the me7 mafs are rotated to the pre me7 ones.
I wasn't trying to cause trouble honest. In actual fact I thought if you had my MAF/Airbox then it would save you the hassle as the hole/MAF housing is already 3" - but there again if the loom is different - it might not work - so it looks like you are fine with the shiny thing.
It is easier to use the me7 air box lid as it's 3" but I want to be awkward and have turbo wrote on mine got to add at least 10bhp
martin_r_smith (Tuesday 10th February 2015)
There are currently 3 users browsing this thread. (0 members and 3 guests)
