Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Mystery rattle
    Moderator
    happy
    shepbomb's Avatar
    Jun 2011
    Doncaster
    374
    Mystery rattle
    Right, the 850 has now developed a mystery rattle it sounds like it is coming from the rear but as usual it is a nightmare to tell, this seems to have arisen since blanking plate was fitted, but I am 99.9 percent certain this has nothing to do with it as it only occurs over rough surfaces and bumps, does anybody have any suggestions, or should I just pester pete to have a look lol
    Old Cars: Mazda6, Laguna 2.2, S40 T4, Passat 1.8t, Celica GT4, Legacy GTB, Golf VR6, S70 2.5t, C70 T5
    Current Car:850t5
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Lol im moving away if you havent sorted it by friday ill look it over
    stevie69's Avatar
    Jul 2008
    fife scotland
    36
    it had a rattle years ago from the back..was the handbrake shoes that had fell apart..the blanking plate has never ever been touched..
    endo-t5's Avatar
    Feb 2010
    wirral,cheshire
    2
    I had a rattle on my 850 estate turned out to be the tailgate striker that is fitted to the car has a plastic sleeve that wears out and I have sorted it with some black insulation tape ans the seats have same thing so check them out also the bottom lock on the seat base sometimes wear but I'd check stricken plate as I checked all over mine and did my head in for months
  5. #5
    this member hass no status
    thunderace's Avatar
    Jun 2005
    Doncaster
    31
    Loose pad retainer perhaps? Disappears when you brake.
  6. #6
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by shepbomb View Post
    Hi
    I get some rattles over bumps and surfaces even though I've just changed half of my suspension components. My local ATS had a look some time ago and said it was the exhaust heat shield rattling against the exhaust pipe as the heat shield had come a bit loose. Give that a try!
    Regards
    James
  7. #7
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    You haven't left the misses in the boot have u
  8. The Following User Says Thank You to t5 pete For This Useful Post:
    JamesT5 (Monday 27th August 2012)
  9. #8
    emm's Avatar
    Nov 2010
    Cheltenham
    1
    Mine has the same problem, wish I could fine it.
  10. #9
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    My money is on the exhaust in some shape or form, being the issues...........
  11. #10
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    my money's on rear brake pads
    It's a 5 Cylinder Orchestra!
  12. #11
    t5 stealth's Avatar
    Oct 2005
    brighton
    462
    iv seen a few 850s with a rattle on rear,
    2 main things it sems to be is rear pads rattle on the pins that hold them in,
    and the other one is in the bottom of the rear springs is a nut,it goes through a dome plate to hold the spring to the lower arm,
    this nut may not be tight enough as you say youve changed suspension,check its tight enough,
    T5 STEALTH
    http://www.vpcuk.org/forums/album.php?albumid=21 AND A MERCURY CAPRI
    RIP alan (kyebosh)
  13. #12
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by jdavis View Post
    This thread is beginning to sound like a Casino.
  14. #13
    t5 stealth's Avatar
    Oct 2005
    brighton
    462
    usualy if you thump the tyre it will make the noise,makes it easier to pin point ?
    T5 STEALTH
    RIP alan (kyebosh)
  15. #14
    nobananas's Avatar
    Feb 2005
    201
    My bet is what T5 stealth said. The nut holding down the bottom of the spring retainer. Had the same happen to mine and it was a §§§§§§ to find !
    Modifications: Nowt.....yet !
    Daily driver: 855 R in Black,
  16. #15
    nobananas's Avatar
    Feb 2005
    201
    Quote Originally Posted by nobananas View Post
    Oh, so that's what happens when you say §§§§§§ !!
  17. #16
    t5 stealth's Avatar
    Oct 2005
    brighton
    462
    pmsl
    T5 STEALTH
    RIP alan (kyebosh)
  18. #17
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    §§§§§§ - just testing.....
  19. #18
    Moderator
    happy
    shepbomb's Avatar
    Jun 2011
    Doncaster
    374
    I aint changed the suspension but will have a look tomorrow as it was dark when getting in from work :-(
    Current Car:850t5
  20. #19
    nobananas's Avatar
    Feb 2005
    201
    I hadn't touched mine in years it just came loose, actually now I think about it mine broke off completely leaving the big lumpy bit rattling around in the bottom of the spring !
  21. #20
    emm's Avatar
    Nov 2010
    Cheltenham
    1
    Order the new spring retainers and we'll see if that fixes it lol.
    I've changed my suspension could i ask where the "The nut holding down the bottom of the spring retainer" is located?
    Andy
