Results 1 to 8 of 8
    wright_t5's Avatar
    Sep 2004
    Cambridge
    2
    Car wont run..... Petrol.. missing
    Hi,
    Simple facts.....
    Car wont run, thought it was sparks, not the problem, fuel...
    Inject fuel direct into manifold through vacumm hole, car runs....
    Changed Filter... pump buzzes, no fuel pressure, no leaks...
    Seats out to find fuel pump, oh, Tanks about quarter full
    Any body got a clue what might be the problem..
    Al115's Avatar
    Feb 2005
    Herts
    672
    So the pump runs but fuel doesn't get to the rail?
    I'd look at the pump and the fuel pressure regulator?
    Alastair
    wright_t5's Avatar
    Sep 2004
    Cambridge
    2
    Quote Originally Posted by Al115 View Post
    Pumps in the tank, wheres the reg?
    Al115's Avatar
    Feb 2005
    Herts
    672
    Behind the fuel rail.
    Alastair
  5. #5
    wright_t5's Avatar
    Sep 2004
    Cambridge
    2
    Fuel Gauge telling lies....
    HI,
    The problem continues....
    The initial problem was that the pick up in the tank, which also holds the float came adrift in the tank, the float then "floated" on the fuel but as it was dislodge gave false reading on the fuel gauge... so the reason the car wouldn't run was "we ran out of fuel"
    Next, the car has just run out again.... indicating 80 miles to go on the fuel gauge!!!!
    Anyone know if you can reset the gauges so they read right???
  6. #6
    Jul 2008
    6
    they sender/float cant be in the right position by the sounds of things. could be wrong but its the first id check and double check
  7. #7
    Old Fart
    Porcine_Aviator's Avatar
    Jul 2008
    Weston on the Mud Somerset or in it if you get the tide wrong.
    699
    If it's the sender thats shot have a word with Rufe, he does a very very good price on them
    “If people let the government decide what foods they eat and what medicines they take, their bodies will soon be in as sorry a state as the souls who live under tyranny.” Thomas Jefferson (1778)
    Did you know the EU says that you can't claim that drinking water prevents dehydration. So now you know for sure what many of have known for years that the EU is run by a bunch of nutters.
  8. #8
    Trying to keep on top of it
    LeeT5's Avatar
    Oct 2004
    Kent
    974
    Wink
    Quote Originally Posted by wright_t5 View Post
    HI,
    You could of checked for lack of fuel in about 30 seconds with an amp meter and a modified fuse! amp draw above 6 = seized pump, below 3 = no fuel. Simples
    2004 V70R 6spd manual:: Custom JRtuning REMAP @ peak 21psi :: Custom 2.75" exhaust :: TTV SMF + 07 Clutch :: WG 5.0 psi :: Tints :: IPD R gauge Rev.3 :: CFWerks door pod :: Forge CBV + yellow spring :: Windowed stock housing + blue filter :: Powerflex :: Superpro Engine mount :: Brembo Dot 5.1 :: TW FMIC :: Eibach 5mm spacers :: Brembo 330mm drilled discs :: iMiV 'Classic'+ BT :: D2R XENARC 5500k + LED H7 + LED H3 :: VolvoTech CFE OBD-V1 :: See garage for full mod list
