difference between 310 and 340 rica
Post 94930 by heyes on 2006-04-02 22:33:36
Almost there with preparing my v70 t5 for a vt experience. Is the main difference between them, a bigger turbo or are there some other bits and pieces. Is the exhaust different.
Post 94933 by Wobbly Dave on 2006-04-02 22:45:54
to get the real benefit from the 19T (which on it's own is not all that) you need the correct map and a ferrita downpipe. Depends on your budget but I believe VT do a standard and a custom map for the bigger turbo. The flow rates/characteristics on the 19T are a lot different to the 16T. 16T has an plain oil bearing - where as the 19T has a ball bearing bearing. The 19T can sustain a higher flow rate. Having a cat back can also assist when the flow rate increases. Avoid cone filters unless properly ducted/shielded You would need to seek their advice as to what is the best route to achieve good power.
Post 95001 by pault5 on 2006-04-03 12:17:14
the difference is like night and day... so is the cost!
