ICE Question
Post 88126 by JimboT5 on 2006-03-09 23:27:43
Hi all, I spent most of today crouched in my boot rewiring the rather Heath Robinson cd changer set up that the previous owner *COUGH COUGH* installed. At some point it's had new drive units which have been left but also a subwoofer and other bits that are long gone as I removed miles of unused wires, but the rear door speakers and the tweeters are fed from crossover type boxes. On the boxes it has a switch marked "tweeter" and you can either select "flat" or "-3dB". It's currently on flat and I was wondering what the -3dB setting would actually do soundwise? My next job is to remove all the stock speaker wiring (basically nasty cheap doorbell wire) and replace it with nice see-through copper stuff!
Post 88128 by Vikingxl on 2006-03-09 23:28:50
Where are you Mullet boy your expert advice is required!
Post 88137 by racer on 2006-03-09 23:50:33
-3dB switch will sound like you turned the treble dial down on your stereo. Probably provided so you can run tweeters that would normally sound too bright with the rest of your system. See-through copper? The man's found a new element! :duck:
Post 88170 by t5tart on 2006-03-10 00:43:09
-3db basically is a tweeter cut to let the mid range come through a bit more if it sounds a bit tinny select the -3db will reduce the output to the tweeters
Post 88318 by JimboT5 on 2006-03-10 15:21:47
Many thanks for the replies guys, I shall give it a try and see if I prefer it. I just wanted to make sure I wasn't going to blow anything up first! Don't get too excited about the see-through copper stuff! Just upgrading the standard aluminium stranded cable with something a little better! :anmflower
Post 88321 by BlackBeast on 2006-03-10 15:38:24
[QUOTE=JimboT5] but the rear door speakers and the tweeters are fed from crossover type boxes. [/QUOTE] Jimbo, where are these boxes located?
Post 88327 by JimboT5 on 2006-03-10 16:29:24
[QUOTE=BlackBeast]Jimbo, where are these boxes located?[/QUOTE] Hi there, I'm not sure 100% sure these are standard and I think they we're fitted by one of the previous owners - BUT mine are located in the recess behind the head unit and accessible from the passenger side footwell. You just remove the trim under the glovebox secured with three star headed screws, pull back the carpet and remove the large peice of black plastic trim that acts as a kick panel for the recess behind the headunit. I'd be interested to see if other 850s have them too.
Post 88334 by S60D5 on 2006-03-10 16:54:45
[QUOTE=JimboT5]Hi there, I'm not sure 100% sure these are standard and I think they we're fitted by one of the previous owners - BUT mine are located in the recess behind the head unit and accessible from the passenger side footwell. You just remove the trim under the glovebox secured with three star headed screws, pull back the carpet and remove the large peice of black plastic trim that acts as a kick panel for the recess behind the headunit. I'd be interested to see if other 850s have them too.[/QUOTE] They're not standard, were fitted along with the speakers when changed in the mid-late 90's for the cars first owner ;)
Post 88506 by mulletboy2 on 2006-03-11 00:31:19
It will almost definitely sound better set to -3dB (for those up front anyway). Sounds should come from infront of you, not behind.. with the exception of bass, which you can get away with behind you without too much of a negative effect. Reducing the treble coming from behind you is a good idea.
