Mystery of the Exhaust Fumes II
Post 80338 by JimboT5 on 2006-02-13 17:20:14
Hopefully this will be useful to anyone who may have a similar problem in the future! Basically since buying the car I've noticed a smell of exhaust gases when the car is stationary and when the air con is on. Today I had a look and could see something venting from the area in the photo. Image I got it checked out when booking my service and the mechanic pointed out that the crankcase breather hose had come apart, where the pipe meets the rubber boot connecter thing. I managed to get the pipe relocated although it was tough, all the pipes have been routed the wrong side of the big turbo tubey thingy so they don't have much slack. Oh well, I'm pleased it didn't turn out to be a massively expensive problem after all! :)
Post 80366 by S60D5 on 2006-02-13 18:33:51
And Charlwood Volvo didn't spot this ?????
Post 80380 by Vikingxl on 2006-02-13 19:24:23
Nasty could have given you a nice carbon monoxide headache there mate!
Post 80424 by JimboT5 on 2006-02-13 22:09:15
[QUOTE=S60D5]And Charlwood Volvo didn't spot this ?????[/QUOTE] Obviously not! I daresay it will pop out again so I'm going to secure it with some jubilee clips, but the fact remains the pipes have been put back wrong which caused the problem in the first place. Think I'll steer well clear of that "specialist" in future. [QUOTE=vikingt5]Nasty could have given you a nice carbon monoxide headache there mate![/QUOTE] Yeah! It's lucky it was quite a strong smell or it might of gone unnoticed, and then who knows :bricks:
Post 80475 by S60D5 on 2006-02-13 23:35:45
[QUOTE=JimboT5]Obviously not! I daresay it will pop out again so I'm going to secure it with some jubilee clips, but the fact remains the pipes have been put back wrong which caused the problem in the first place. Think I'll steer well clear of that "specialist" in future. [/QUOTE] Yeah good call - I thought the pipes you mention were a bit tight fitting! I'll be using SW Autos in Kent in future - good reviews!!
Post 80484 by Unknown on 2006-02-14 00:08:05
glad it was spotted ok in time!
Post 80529 by S60D5 on 2006-02-14 10:11:42
Just to give you all a background to this problem as you may not be aware: The car was originally mine... The engine was replaced by Charlwood Volvo in Surrey (a specialist) last year after an engine transplant due to a catastrophic failure in Germany. After the engine replacement, I complained of fumes entering the car from after a run when the car was at idle. I took it back to Charlwood and they had the car for the entire day to try and track the fault. They couldn't find anything but replaced the pollen filter, which seemed to make the problem slightly better for a while. James takes it to his (non Volvo specialist) local garage and they spot the fault straight away! Unbelievable.
Post 80531 by JimboT5 on 2006-02-14 10:28:23
Does make you wonder doesn't it? I remember you warned me not to go there anyway after they messed you about for your MOT.
Post 80533 by S60D5 on 2006-02-14 10:41:36
[QUOTE=JimboT5]Does make you wonder doesn't it? I remember you warned me not to go there anyway after they messed you about for your MOT.[/QUOTE] Ah yes - Told to turn up anytime before 1.00pm for my MOT - so I get there about 11.00 (after a 40 mile journey) promply to be told that they won't be able to fit me in that day as I should have turned up at 8.00am when they open. Left the car with them, didn't even get a phonecall to say the work was done, so wandered back to the garage at 5.30pm and they still hadn't done it! Their customer service is lacking somewhat, as are their timekeeping skills. Thats why I'll pay more to have my services at the main-dealer (in Havant) and get a courtesy car for the day so I don't have to spent the entire day in a village boozer getting thouroughly bored. Any work needing doing or minor servicing (every 6 months) will be done by either ACC UK or SW Autos.
