Wiper issues 1997 940 2.3LPT
Post 820201 by ProjectLolvo on 2020-08-10 16:02:53
Hi all, you might have caught my last build thread with the green S60 or maybe not, but treated myself to a 940 a couple of months ago with a view to doing a bit of drifting. I'll cut to the chase, the horn, among other things, was not working on the 940 when I bought it. It was making noises, but both the high and low modules were just making coughing noises when the button was pressed. Rather than replace them with something normal, I had a tritone airhorn kit lying around that my brother bought for his daily and never fitted. Either way, after much head-scratching, it is now fitted, and works with the old horn button. My problem is this; there are two yellow wires, and two blue, a mixed pair of which were going to each horn on the bumper. I pulled them all, tapped into one of the blue for my relay to the air compressor for the horn, and have left the others. I have just realised that the wipers must be somehow on the same loop, because they now aren't working. It isn't the stalk or a problem inside the column, as the rear wiper and washer, controlled by the same stalk, works fine. I think the issue lies in what I have left unplugged down at the bumper. What I want to know is how I can get the wipers to work again. Tl;dr, I have two yellow wires and two blue from the old horn, one of the blues goes to my new switch for new horn, and the others are dangling. My wipers now dont work. Someone pls help [emoji23] Have included a wiring diagram I think is relevant in this post [emoji106]Image Sent from my SM-G955F using Tapatalk
Post 820202 by Dangerous Dave on 2020-08-10 17:06:39
The horn and the wipers are on the same fuse circuit looking at those diagrams. Silly question maybe but I take it you checked the fuse? (number 15). As the yellow is the live to the horn and the blue is the switched earth via the steering wheel (only needs one wire to go through the squib) Also 940 wiring diagrams: http://myvolvolibrary.info/Tech_files2_ficheiros/940MY95_EN_Wiring_Diagrams_section-3-39.pdf
Post 820203 by ProjectLolvo on 2020-08-10 17:41:05
Yo thanks for getting back to me so quick, yeah first thing was check the fuse and it was fine, but I've pretty much fixed it either way here. Bit of a long workaround, but I took another wire straight from + of battery to the yellows, which I grouped together, then bunched with the wire. Taped it off, and hey presto, wipers work again together with new horn. Just pretty much gone the longest route possible for wiring my new horn into the car, because I'm an idiot and it's taken me f*****g days to learn. Cheers for your help [emoji108] Sent from my SM-G955F using Tapatalk
Post 820204 by Dangerous Dave on 2020-08-10 20:26:45
We all have to learn somehow bud :) Maybe disturbing the wiring caused a break somewhere, especially with the age of the car.
