Post 819252 by Nick0 on 2019-11-15 12:04:03
Hi everyone,
last time I asked this question (5 years ago or more), the verdict was Vredestein Ultrac Sessanta, these have been excellent tyres, I need 4 more now but they're no longer available!
what is the recommended tyre nowadays (18 inch wheels on mine)?
thanks in advance as always,
nick0
Post 819281 by MoleT-5R on 2019-11-17 11:52:18
I can't help here sorry, as I buy as cheap as possible now for where I live, as many of my expensive tyres have been killed either by potholes or the majority by pulling over to let others pass in narrow lanes and tearing sidewalls on rocks sticking out of the banks. Only time I spend a bit more now is track tyres for the T-5R's (R888's) or all season tyres on the XC90 (General GT's). I'll try to remember tomorrow to ask my local tyre supplier, as they have been [COLOR=#333333]Vredestein dealers for over 20 years and should know wht is the current replacement of that particular tyre.[/COLOR]
Post 819282 by Nick0 on 2019-11-17 19:07:27
[QUOTE=MoleT-5R;819281]I can't help here sorry, as I buy as cheap as possible now for where I live, as many of my expensive tyres have been killed either by potholes or the majority by pulling over to let others pass in narrow lanes and tearing sidewalls on rocks sticking out of the banks. Only time I spend a bit more now is track tyres for the T-5R's (R888's) or all season tyres on the XC90 (General GT's). I'll try to remember tomorrow to ask my local tyre supplier, as they have been [COLOR=#333333]Vredestein dealers for over 20 years and should know wht is the current replacement of that particular tyre.[/COLOR][/QUOTE]
Thanks Mole, the sessantas are discontinued now i would have bought more if i could. Be interesting to hear your further thoughts
Post 819289 by MoleT-5R on 2019-11-18 15:56:59
[QUOTE=Nick0;819282]Thanks Mole, the sessantas are discontinued now i would have bought more if i could. Be interesting to hear your further thoughts[/QUOTE]
Gave them a ring and they suggested Vredestein Satin or Vorti as replacements for the Sessanta's, available in 225 & 235 40 18's, which should be correct for the S60R, only downfall is they mentioned that they are on back order at present, hope that this helps and good luck on choosing your replacements, I hate it when you get used to a tyre and then they stop doing them, I had this with my favourite budget tyre a while back.
Post 819293 by Nick0 on 2019-11-18 23:04:37
[QUOTE=MoleT-5R;819289]Gave them a ring and they suggested Vredestein Satin or Vorti as replacements for the Sessanta's, available in 225 & 235 40 18's, which should be correct for the S60R, only downfall is they mentioned that they are on back order at present, hope that this helps and good luck on choosing your replacements, I hate it when you get used to a tyre and then they stop doing them, I had this with my favourite budget tyre a while back.[/QUOTE]
Thank you sir
Post 819295 by pepinosport on 2019-11-19 13:10:10
I'm gonna buy the new pzero, pz4 for the VR.
Dunlops RT are well priced where I live and are great IMHO. HAd them 3 times
Michelin PS4 are very good but expensive.
Conti premium 6 are excellent allrounders that I have in my b5 rs4 (beware it isn't a sports tyre but can deal with fast road stuff ESPECIALLY in the wet)
Post 819304 by LeeT5 on 2019-11-20 01:35:29
I've had Sessanta's in the past but they are not as good as Dunlop Sport Maxx RT's. The sidewall is lovely and smooth for adding tyre gel and the tread pattern is superb. They are also grippier in the dry.
During winter months I run Vredestein Giugiaro Design Wintrac Xtreme 235/40/18 @ 35psi and they are fantastic.
Post 819308 by Nick0 on 2019-11-20 15:47:44
Thanks chaps. I did a bit of research, there's only one tyre that's A rated for fuel economy and performance in the wet, the Pirelli P7 Cinturato blue, will check out your tips though thank you
Post 819309 by pepinosport on 2019-11-20 18:58:17
[QUOTE=Nick0;819308]Thanks chaps. I did a bit of research, there's only one tyre that's A rated for fuel economy and performance in the wet, the Pirelli P7 Cinturato blue, will check out your tips though thank you[/QUOTE]
I use those for driving training in BMWs. They're good... good for drifting:rolling_e
Also had them in a Jag XE...very low grip on greasy roads.
Also not a sports tyre at all in terms of body control nor steering feel.
Don't trust that much the ratings on the labels. These tests are perfomed in controlled conditions and only in straight line and without any lateral or vertical dynamics involved. And although they are good indicators of the rubber's performance, they fail to show "real world performance". I know bec I work with people that issue these EU tyre ratings.
Have you checked tyrereviews.co.uk? They have loads of info ;)
Post 819310 by Nick0 on 2019-11-20 22:56:56
[QUOTE=pepinosport;819309]I use those for driving training in BMWs. They're good... good for drifting:rolling_e
Have you checked tyrereviews.co.uk? They have loads of info ;)[/QUOTE]
Good shout thank you !
Post 819311 by kmb on 2019-11-21 12:50:21
I took a chance on some lower to middle ground tyres for the C30 and have been very pleasantly surprised. I've had Vredestein before and these are similar market placement...
They were nearly all I could get at the time, due to the less common 215 45 18 profile and short time span I had available, they're called Marshal MU12's.
I initially scoffed at the make but checked a number of reviews on the the predecessor MU11 and thought they were worth a try at about £95 fitted a corner... low expectations were met with low noise, good and very predictable grip in wet and dry, reasonable wear.
After 5k miles with them I would 100% buy again and I'm normally very picky with mid to premium tyres!
As an edit added note - They are Y rated, so good in excess of 186mph :funkybana
Post 819312 by Rebel Rebel on 2019-11-21 15:28:59
I used to run the S60R with PZero Nero's and was always happy with performance and life. I haven't bought them for a while, and I know that you have to shop around to get the best price.
Post 819314 by Nick0 on 2019-11-21 21:02:53
Thank you gents. I always had P zeros on my Saabs, no complaints
