Post 819161 by Tomcat on 2019-10-25 14:23:05
As the engine in my R has just about had it I'm going to be replacing it with a 2003 Me7 motor out of an S60, I already have the engine but I need advice on what I need to do to adapt it to the older car. Any advice would be appreciated as I'm waiting to fit it next week.
Post 819162 by LeeT5 on 2019-10-25 20:49:03
I'm guessing a 2003 S60 wiring harness would be a good start.
Post 819163 by PNuT on 2019-10-26 05:37:10
Difficult swap, I have tried it the other way round and the problems come with the two different sets of electronics between the main car and engine! I suspect you would struggle to set the diagnostic systems up in case of a problem....
I suspect the easiest way would be to use the pre Me7 head on the Me7 block and keep the pre Me7 system but I am guessing you want a complete transfer?
Failing that I would try and find a Me7 70 classic and steal the entire wiring loom fuse box etc.....
Post 819172 by Tomcat on 2019-10-27 12:34:08
I’m not actually using the Me7 systems, I’ll be adding the older inlet manifold,throttle, dizzy etc.. Basically converting it to run on the older stuff.
Post 819173 by PNuT on 2019-10-27 16:25:09
[QUOTE=Tomcat;819172]I’m not actually using the Me7 systems, I’ll be adding the older inlet manifold,throttle, dizzy etc.. Basically converting it to run on the older stuff.[/QUOTE]
Can you add a dizzy to an Me7 head?
I guess you will have to blank the VVT as well....
Post 819180 by Tomcat on 2019-10-29 22:31:29
[QUOTE=PNuT;819173]Can you add a dizzy to an Me7 head?
I guess you will have to blank the VVT as well....[/QUOTE]
Apparently so, halfway through the conversion at the minute so I'll let you know in a few days what actually needs to be swapped. Currently got the turbo plumbing sorted, the engine mounts, just need to confirm the fuel pipe routing and then adding the distrubutor and cam sensor etc..
Post 819181 by kmb on 2019-10-30 09:05:32
Good luck with it all, look forward to hearing the progress.
Post 819182 by MoleT-5R on 2019-11-01 00:00:43
I'm sure Oblark did this in his 850 or 240 project, so there will be a mine of information in his project threads. ...good to see you back Craig and the v70r geting yet more love, good luck with the swap
Post 819188 by Tomcat on 2019-11-02 07:18:37
Well it's in and running, just need to finess the details like getting the engine covers to fit, sort proper routing for the fuel pipes and bleed my clutch.. Hoping to test run it in a couple of hours.
Post 819189 by MoleT-5R on 2019-11-02 09:57:21
clutch bleeding....good luck with that Craig, my last attempt on Gul was a nightmare to get bled properly
Post 819191 by Tomcat on 2019-11-02 10:27:52
[QUOTE=MoleT-5R;819189]clutch bleeding....good luck with that Craig, my last attempt on Gul was a nightmare to get bled properly[/QUOTE]
Done!! Was a bit of a pig but got there in the end.. Took it for a spin, it's REALLY quiet.. Not sure if I have a minor leak from something somewhere, stopped the car for a minute in the rain and was left with a lovely rainbow under the car when I moved it. Not really pushed it yet to see what it goes like.
Post 819193 by Tomcat on 2019-11-02 16:28:19
[QUOTE=LeeT5;819192]Is it still only 2wd??[/QUOTE]
Yup, I didn't go the whole hog and convert it to 4wd as well, I only had a week off work to do the engine conversion as it was,lol
Post 819194 by MoleT-5R on 2019-11-02 22:27:08
Good to her the old girl is going again....good job sir
Post 819195 by Tomcat on 2019-11-03 11:24:40
Thanks buddy, surprised she's still going after all these years tbh
Post 819201 by MoleT-5R on 2019-11-04 11:36:18
[QUOTE=Tomcat;819195]Thanks buddy, surprised she's still going after all these years tbh[/QUOTE]
I keep getting a bollocking for not fixing Jayne's one yet, may be this winter it will get done, then it has waited 6 years, so I really should pull my finger out and get on with it.
