Post 818965 by freddyboyj on 2019-09-06 20:31:49
hi all i have a 2004 s80 d5 goes like the clappers but have a problem with the gear box when hot. i have changed transmission fluid then it ran better for a few days,i wondered if there was a filter and where it is located, any advice welcome. thanks
Post 818967 by LeeT5 on 2019-09-07 10:03:18
[QUOTE=freddyboyj;818965]hi all i have a 2004 s80 d5 goes like the clappers but have a problem with the gear box when hot. i have changed transmission fluid then it ran better for a few days,i wondered if there was a filter and where it is located, any advice welcome. thanks[/QUOTE]
There is no filter.
Sounds like the box may be slipping when hot? if so, it's likely the transmission bands are knackered.
New gearbox mate or overhaul!!
Post 818969 by Harvey on 2019-09-07 10:11:45
Try to get somebody to reset the gearbox software adaptation for a fluid change.
The daft thing is there is a filter in the gearbox but is got to be totally stripped to pieces to get to it, Definitely not a DIY job.
correct fluid level when hot ? , As said looking like a rebuild is required.
Post 818973 by LeeT5 on 2019-09-07 10:42:58
[QUOTE=Harvey;818969]Try to get somebody to reset the gearbox software adaptation for a fluid change.
correct fluid level when hot ? , As said looking like a rebuild is required.[/QUOTE]
Oh yes, gearbox adaption may help (doesn't in most cases and if it does, it lasts about 10 miles).
Reference the filter.....Hence the rebuild! :wink:
Post 818974 by freddyboyj on 2019-09-07 11:20:28
[QUOTE=LeeT5;818967]There is no filter.
New gearbox mate or overhaul!![/QUOTE]
Thanks for the speedy reply, will see if i can pick up a replacement box
Post 818975 by freddyboyj on 2019-09-07 11:23:44
Post 818976 by freddyboyj on 2019-09-07 11:24:18
[QUOTE=LeeT5;818973]Oh yes, gearbox adaption may help (doesn't in most cases and if it does, it lasts about 10 miles).
Reference the filter.....Hence the rebuild! :wink:[/QUOTE]
