Post 818634 by kmb on 2019-06-04 22:05:00
Evening all,
My C30 T5 is nearing 52k miles and I'd like to change the plugs, no issues with the current OEM ones, but good to keep on top of serviceable items.
My question is that a few years ago we used to be able to buy OEM Volvo plugs for £30 a set of 5, but now prices seem double and I've lost track of the best place to get them for a decent price.
I'll give Rufe (FRF Volvo) a call, but if anyone else has somewhere to get them for a good price then please could you let me know?
Thanks in advance.
Post 818635 by Dangerous Dave on 2019-06-04 22:45:43
I use the Bosch alternatives in my 850, can usually find them cheaper.
Looking at the Bosch website they list the FR7NI33 for the C30 T5
Ebay lists them at around £7 each
Post 818636 by kmb on 2019-06-05 12:14:41
Thanks Dave, I'm keen to use OEM Volvo due to the various stories I've read on the forums about other plugs not working as well, although I'm not sure how much truth there is in them!
Post 818642 by Ric@rdo on 2019-06-06 11:04:28
I´ve been running non-OEM plugs for a few years and had no issues. In fact, you should run colder plugs (properly gapped) because it will help with knock prevention.
I recommend you use the NGK Iridium IX Spark Plugs LFR7AIX (Stock 2309) with a gap of 0.61mm. They are one step colder from OEM. I´ve used these ones and I´m even running a two step colder plugs at the moment with no issues, even when starting the engine cold in the morning.
Post 818644 by LeeT5 on 2019-06-06 13:28:55
[QUOTE=Ric@rdo;818642]I´ve been running non-OEM plugs for a few years and had no issues. In fact, you should run colder plugs (properly gapped) because it will help with knock prevention.
I recommend you use the NGK Iridium IX Spark Plugs LFR7AIX (Stock 2309) with a gap of 0.61mm. They are one step colder from OEM. I´ve used these ones and I´m even running a two step colder plugs at the moment with no issues, even when starting the engine cold in the morning.[/QUOTE]
Aren't they the same as what Ford use in the Focus RS 2.5?
Post 818647 by Ric@rdo on 2019-06-06 13:53:09
[QUOTE=LeeT5;818644]Aren't they the same as what Ford use in the Focus RS 2.5?[/QUOTE]
Don't know that info Lee.
Post 818656 by kmb on 2019-06-07 09:58:45
Thanks all for the comments, any good places to buy? I'm a bit out of touch with UK retailers and bargains since being mainly in France for the last 10 years.
Post 818660 by Ric@rdo on 2019-06-07 14:52:42
I bought from here last time. They don-t have the NGK Iridium but these are also one step colder and will be good on your car/engine. I-ve been running these but two step colder and work really well.
https://www.gsparkplug.com/1x-denso-iridium-power-spark-plugs-ikh24-ikh24-267700-4280-2677004280-5346.html
Post 818691 by kmb on 2019-06-11 09:55:33
[QUOTE=Ric@rdo;818660]I bought from here last time. They don-t have the NGK Iridium but these are also one step colder and will be good on your car/engine. I-ve been running these but two step colder and work really well.
https://www.gsparkplug.com/1x-denso-iridium-power-spark-plugs-ikh24-ikh24-267700-4280-2677004280-5346.html[/QUOTE]
Checked the link - They are now listing NGK iridium for my car: https://www.gsparkplug.com/1x-ngk-iridium-spark-plug-ilfr6b-6481.html
Post 818692 by kmb on 2019-06-11 10:21:46
Well, just for an update on this, phoned FRF in Swansea with discount code C3, as usual they delivered nicely beating nearly all prices on the net including delivery, so I decided to play safe and stick with the originals this time, since NGK Iridium were the same price.
£46 delivered, 5x Volvo original plugs, part number 30751806.
Post 818767 by kmb on 2019-07-13 13:04:01
Fitted yesterday, the old plugs taken out of my 2010 C30 T5 were the original with nearly 53k miles (annoyingly the Ford Motor Company stamped iridium versions), glad to get the new plugs in, easy job for the fitting and torqued up correctly to 30Nm.
Quite shocked at how much difference new OEM Volvo plugs has made, even though the originals were in top condition with some slight electrode wear, it's certainly not a placebo affect - The car revs slightly more freely, pops and crackles a little more, feels like I've gained 20-30bhp throughout... Dread to think what the plugs would feel like if I left them in to the later 75k service interval.
