how do i reset immobiliser on 95 850 so i can program new key fob ?
Post 818232 by pv544t5 on 2019-03-06 17:53:08
Ok -so i have a bit of a problem. I armed my 95 850 using the keyfob and then the keyfob broke.how do i now reset the alarm / immobiliser so i can program a new fob ?
Post 818318 by nobananas on 2019-03-23 19:59:36
I got stuck a few years ago in a Tesco car park when my key fob just stopped working for some reason. Opening the door with the key resulted in the alarm sounding, even putting the key in the ignition and turning the ignition on didn't deactivate the alarm and the immobilizer wouldn't deactivate. Didn't matter what I did (disconnecting battery, leaving it for a few hours, new keyfob battery etc) I couldn't stop the alarm sounding or deactivate the immobiliser. I found out that what I had to do was open the vehicle, let the alarm sound then wait (23 seconds I believe !) for the alarm to stop (the hazards continue to flash though). As soon as the alarm stopped I turned on the ignition, the hazards did a funny double flash then stopped, the car then started !. I got it home, locked it up with the key intending to look at it the next day, went out the next morning to find the key fob was working again and it's never done it since !. Don't know if this helps, mine is a 96 850R.
Post 818334 by Dangerous Dave on 2019-03-25 18:09:01
Mr Bananas you are a superstar. You'll never guess what happened to me tonight. Tried to open the car with the fob, nothing. The fob was beeping so I knew the battery was ok. Problem is my door lock doesn't work and the boot lock doesn't either so I had no way of opening the car... Anyway after an hour I managed to get the locking system to unlock but then the alarm was going off and the car wouldn't start. I used your method above and hey presto it started and disabled the alarm. I re-registered my fob and another one I have lying around and all is well. The alarm must have 'forgotten' my fob for some reason. Your info saved the day!
Post 818338 by LeeT5 on 2019-03-26 21:13:06
[QUOTE=Dangerous Dave;818334]Mr Bananas you are a superstar. You'll never guess what happened to me tonight. Tried to open the car with the fob, nothing. The fob was beeping so I knew the battery was ok. Problem is my door lock doesn't work and the boot lock doesn't either so I had no way of opening the car... Anyway after an hour I managed to get the locking system to unlock but then the alarm was going off and the car wouldn't start. I used your method above and hey presto it started and disabled the alarm. I re-registered my fob and another one I have lying around and all is well. The alarm must have 'forgotten' my fob for some reason. Your info saved the day![/QUOTE] :uglyhamme Glad you sorted it Dave :smile: Now fix those door locks...:buttkick:
Post 818339 by Dangerous Dave on 2019-03-26 22:27:59
[QUOTE=LeeT5;818338]:uglyhamme Glad you sorted it Dave :smile: Now fix those door locks...:buttkick:[/QUOTE] :P It's because I fitted V70 colour coded handles and tailgate handle. The doorlocks don't exactly swap over so I had to make a frankenlock out of the two but ended up snapping one of the parts which I never got round to replacing. And the tailgate handle I bought didn't have a lock in it, just a blanking plug and the 850 one is different. Need to get some spare locks I'm afraid (or put the old ones back on :) )
Post 818399 by pv544t5 on 2019-04-05 22:24:42
ended up going to main dealer.they removed the relay and re-programmed it to a new keyfob.
Post 818400 by Dangerous Dave on 2019-04-06 15:14:17
How much did they charge (if you don't mind me asking)?
Post 818421 by MoleT-5R on 2019-04-10 12:52:28
Thats some handy info there from Mr Nobananas, did something very similar many years ago to get my olive T-5r mobile again, when I had to use the spare key on which the fob didn't work. It seems you can trick the alarm/immobiliser into turning off.
