Forged pistons t4 b4194t2
Post 816414 by Tommy t4 on 2018-05-23 12:59:10
Gentlemen, having a bit of trouble finding some forged pistons for my engine, have rods. Can only get hold of 5 pistons or rods for the t5 engine...anyone know a website or point me in the direction of pistons please? Many thanks Tommy
Post 816741 by Tommy t4 on 2018-07-03 17:06:53
Wow proper performance volvos in here.....��
Post 816743 by don kalmar union on 2018-07-03 17:36:16
Have you checked yet how you are going to get the software recalaibrated to run that lot....? Regards, Don. PS you will have to buy a set of five rods for the T5 most likely.... and the standard pistons should be OK depending on just where you are ending up..... and you WILL need the very best calibrations from someone who knows these engines... and not to be forgotten is the old Siemens ECU that is still protected by an impenetrable pincode......
Post 816748 by 960kg on 2018-07-04 10:02:29
I wouln`t underestimate Tommy t4 as he has been playing with T4`s for years. There was a post a few years back on the other side.....where he had sussed out the ECU ......
Post 816757 by Tommy t4 on 2018-07-04 12:51:58
[QUOTE=don kalmar union;816743]Have you checked yet how you are going to get the software recalaibrated to run that lot....? Regards, Don. PS you will have to buy a set of five rods for the T5 most likely.... and the standard pistons should be OK depending on just where you are ending up..... and you WILL need the very best calibrations from someone who knows these engines... and not to be forgotten is the old Siemens ECU that is still protected by an impenetrable pincode......[/QUOTE] I case you missed my signature, I have a b4194t2 in a phase 2 Volvo with the later ecu, which isn’t locked, and running well..I have the set of bsr Conrods already (5), but need forged pistons, I did email you a while back asking for directions in that department but to no avail, and also tim Williams, just need good forged pistons to run over 500..I have everything else which I accumulated of the last 5 years, pistons are the last part to the puzzle.. I know I can get custom pistons but just thought someone already might have used a good set already.. Thanks
Post 816758 by Tommy t4 on 2018-07-04 12:54:22
Thanks Keith, hope your well..
