Vida login
Post 816170 by jellison on 2018-04-23 19:28:18
I had got Vida installed and running on a pc I bought for the job, but it has been in a cupboard for months.
Come to use it now and popping in the Username as admin (from the read.me file and the Chinese video) to login does not work!!!
Username:
Log in
Registration guide for subscription
Problems with log in?
Please contact your local helpdesk
This machine is registered as Volvo.
VIDA Version: VIDA2014D
Any idea. How do people ever use this stuff. Endless posts on the web with people giving up with it!
And I had it working...............
Post 816176 by stribo on 2018-04-23 22:13:54
Mine login is "1"
Post 816182 by antonys60r on 2018-04-24 07:05:07
Jon it sounds like your Vida is out of date. There is a patch that you can download and this changes the date of expiry. All details of this are on the Volvo owners club forum.
Post 816183 by jellison on 2018-04-24 07:31:53
Ah thanks Anthony, I did see one post on a forum saying this (it said see below link to thread on that, but then no link!).
Found this on Swedespeed. http://forums.swedespeed.com/showthread.php?519649-VIDA-expiration-123117
32bit:
https://drive.google.com/file/d/1WyR...oUGzhlhKp/view
64bit:
https://drive.google.com/file/d/1ZFv...bMfkOdRrs/view
I presume my old Dell Win 7 pc will be 32 bit.
I presume I just run the respective exe and then start Vida again using the same old admin userid. See how that goes.
Might drop you a PM on something else.
Post 816186 by antonys60r on 2018-04-24 12:44:27
That’s the one .I would say your pc would be 32 bit.
Post 816190 by jellison on 2018-04-24 19:08:53
downloaded both, and ran the 32 bit one, the one with 2030 in the title, get a dos pop-up quickly. Retry, seems to take longer (the green bars), but ultimately the same, no joy. Rebooted post running the exe patch and the same again!
Post 816191 by jellison on 2018-04-24 19:13:46
Now get Unknown Error; Please contact you Helpdesk.
This was after I tried the REGISTRATION GUIDE FOR SUBSCRIPTION and popping in ADMIN and admin.
This really is a ££££ing joke.
Post 816192 by jellison on 2018-04-24 19:48:51
The wife just said she will sort it at the weekend!!!! :)
If only these things ran on CARB's.
Right back to to Cleetus McFarrland.
Post 816236 by LeeT5 on 2018-04-29 11:05:10
[QUOTE=jellison;816170]I had got Vida installed and running on a pc I bought for the job, but it has been in a cupboard for months.
Username:
Log in
And I had it working...............[/QUOTE]
It is not because your VIDA is out of date.
I know about the patch, but the fault your getting is to do with Win 7 drivers conflicting with your windows explorer. I had exactly the same issue!
I went on every link, website, contacted guys in the USA, VOC, etc, etc for 6 months!
You'll need to uninstall everything and erase the Hard disk.
Reinstall Windows 7 32bit and do NOT update the windows or even think of connecting it to the internet. Make sure the wifi is disabled and no ethernet cable is plugged in.[U][B]Do not update Explorer whatsoever!!!!
[/B][/U]
Once you've dont that, reinstall VIDA following the instructions to the letter.
Make sure also, that you have sufficient RAM (at least 4GB).
Then, as you've already done, install the correct software patch for your version of Windows 7/VIDA. You must do that in order for VIDA to work.
The Username and password they supplied you will be correct, I can assure you that. Do not try to input anything else.
It's important that no other software, not required by VIDA, is installed - as the root directory will cause conflicts from within Win 7/Explorer. So don't install any third party software. Only install your version of Win 7 and VIDA...NOTHING ELSE!
Obviously make sure your Laptop drivers are installed for the Dell machine before you install VIDA.
Also, make sure you do not install any firewall or anti virus software. You'll only have to uninstall them all and start a fresh again!
Once you get to this stage, if it still does not work, come back to this thread and I will put you in contact with someone who will get it working for you over the phone but not until you've done what I've asked, as he will only do the same.
SO, off you go and Format. Reinstall Windows...then Laptop drivers for processor chip etc...then VIDA...:wave23d:
Post 816239 by davebb on 2018-04-29 15:39:22
Hi also if you have the network disabled it will not work, vida will not talk to Volvo HQ, with the patch installed but it needs to think it can as vida works on the webb browser,
you need to have the correct version of IE,
Dave
Post 816241 by davebb on 2018-04-29 15:45:48
I am running vida on xp reg hack to pro, running 2GB ram, you have to change the ini folder, I all so have a lot of different software running on the laptop without any problem,
Dave
Post 816309 by jellison on 2018-05-11 08:14:28
When I said my VIDA was working, I meant I could log on (reloaded the whole thing from scratch). But never got to the car with it with the DICE USB unit.
When I do that it will not see unit / car when I do read car. The blue USB light is not coming on.
As I reinstalled maybe there is a step to make this sync?
Need as car now developed a bizarre idle issue and does not seem quite right when driving (not far off, but not right). Idles at 1300-1400 no not 800 and slow to come down to that when lifting off or stationary.
Occurred after changed out a new TCV (on next drive of it a day later), but think coincidence as plugged original back in and doing just the same!
Any ideas? To get Vida to see DICE unit?
Post 816310 by LeeT5 on 2018-05-11 08:49:25
[QUOTE=jellison;816309]
Any ideas? To get Vida to see DICE unit?[/QUOTE]
Have you installed the USB drivers? This is done seperately by searching the VIDA directory after installation.
Post 816313 by jellison on 2018-05-11 18:00:46
[QUOTE=LeeT5;816310]Have you installed the USB drivers? This is done seperately by searching the VIDA directory after installation.[/QUOTE]Hi Lee
gonna do that now. I had to uninstall the Vida to get it working again and then run the patch (license runs out end of 2017), get it started but did not see the DICE unit.
So hopefully I'll find in the folder. Thanks.
Post 816315 by jellison on 2018-05-11 18:46:01
tried that. Found the exe, ran and then reread the read me and once more run as admin, neither made any difference and when plugged into car and hit read vehicle the blue light is never on!
Maybe the DICE is stuffed!!
Think I plugged Anthony's into my pc / vida one time and his worked!
Post 816316 by LeeT5 on 2018-05-11 20:34:18
Right. When you open VIDA, does the VIDA icon (next to the clock) turn from yellow to green? It needs to be green. Takes about 1 minute to fire up.
Once it's green, plug in the USB cable to the laptop (You need the DICE powered up by plugging it into the EOBD port). Do you get the windows noise, when you plug in a USB device?
If so, then Windows is seeing the device but the drivers, if not installed correctly, will mean the DICE won't work.
Once it's plugged in, go into the Device manager in Windows and see if you can see the device. It should say 'DICE USB device' or something like that. It should also not have an exclamation mark next to it. You can check in Device manager to see if the device is working. If it is, then it should work!
If the device is not recognised by Windows, then you need to install the drivers from within Windows Device manager. Search the folder for the correct USB drivers for your laptop. Make sure your installing the correct ones - 32-bit (x86) or 64-bit (x64).
Your system will need more than 4GB RAM for it to work on a 64-bit systemand VIDA will not work unless more than 4GB.
Post 816340 by Tee5alive on 2018-05-14 17:49:30
Hi
Im just bumping this topic up as I went to the cars today to run the VIDA on the D5 I just bought that has a cruise fault. I plugged in the laptop as usual booted it all up, went to LOGIN put in the code............NOTHING??
recorded a video on the iphone but cant seem to upload it here?
Anway the progress bar starts to load maybe three bars then jumps back to a blank slot again or I get "unexpected fault contact your helpdesk"???
The DICE is flashing the right LED's but thats as far as I get?
So Im stuffed - NO DIAGNOSTICS :help: :mad:
The same as the OP mine WAS working perfectly now nothing? Its just been sat in the house in a safe place since last use battery kept charged - I reckon they put a 'time destroy' on these programs at a certain time they ALL stop working?
(Going to try a few things Lee has listed!)
Post 816341 by LeeT5 on 2018-05-14 18:45:28
If you haven’t done so, you need to patch The Vida software.
Then it will work.
Post 816342 by Tee5alive on 2018-05-14 22:57:59
[QUOTE=LeeT5;816341]If you haven’t done so, you need to patch The Vida software.
Then it will work.[/QUOTE]
cheers mate will do!
Post 816349 by Tee5alive on 2018-05-15 13:40:56
Found out last nice that the laptop doesnt appear to even be SEEING the Dice?? When plugged into the car the LED's are all dancy happily but no software link LED?
Where are these patches found online please? I am the same as the OP bought a pre-programmed laptop with all the gear on it including wiring diagrams, you name it! I wonder if its the SAME person selling these laptops knowing they will work for maybe 1 or 2 diags THEN totally go FUBAR??
Post 816356 by LeeT5 on 2018-05-15 21:33:09
When you plug in the DICE to the laptop, is it recognised in the device manager?
Post 816369 by Tee5alive on 2018-05-16 19:01:26
No I put the device manager up and no sign of it in the list! So more wrong than I thought. As I bought the laptop preloaded I cant delete windows and do a reload as I dont have the original Windows 7 disc. I do have the disc for VIDA though.
There is nothing else on there except VIDA. Im getting a green light on the 'traffic lights to say VIDA is running but I cant login?
Post 816370 by LeeT5 on 2018-05-17 08:50:22
When the laptop is on and VIDA is off, DICE plugged into the car and ignition in pos.2, do you get the ‘bong bing’ tone on the laptop when you connect the usb?
Connect the usb last!
Please clarify this as it’s important.
Watch the desktop and see if any messages appear. Also, do you then, shortly after, get a ‘bing bong’ tone?
Post 816371 by Tee5alive on 2018-05-17 09:25:15
I will try this Lee and find out I dont believe it did 'bing bong' but Ill go down the car and try it, thanks.
Post 816372 by Tee5alive on 2018-05-17 11:59:01
UPDATE after going to the car
Plugged into the car DICE shows this
[ATTACH=CONFIG]32098[/ATTACH]
Put in the login code and press ENTER it starts loading
[ATTACH=CONFIG]32099[/ATTACH]
The bars get to this point then BOOM!! fault
[ATTACH=CONFIG]32100[/ATTACH]
I get this come up as the OP does
[ATTACH=CONFIG]32101[/ATTACH]
This is the USB BUS status doesnt appear to be showing the DICE - BUT gettting the 'bing bong'
[ATTACH=CONFIG]32102[/ATTACH]
DICE hardware showing as 'working correctly'???
[ATTACH=CONFIG]32103[/ATTACH]
SO looking like my VIDA software is FUBAR?
Tried several different sequences of plugging in and connecting but same result
Post 816379 by LeeT5 on 2018-05-17 18:11:39
So, to clarify...Do you get the 'Bong bing' (low pitched tone followed by high pitched tone) and then 'bing bong' after?
When you get the 'Bong bing' it means Windows has recognised the USB device. If you then get 'Bing bong' shortly after, or anytime after, it means Windows has kicked out the USB device as there's either a conflict or software not installed so Windows cannot configure the device.
I'm not being daft but you can see why this is important!!!
You need to right click on the DICE in Device manager and check if it says "no conflicts" or "Device is working properly". This will be in Properties of the device that's plugged in.
If everything is good here, then it looks like if requires the software flash to update VIDA.
Post 816387 by Tee5alive on 2018-05-17 23:46:03
Yes I get the 'bing bong' accepting the dice plug in and none after that so it doesn't kick it out. But as shown in the pics above its not showing in Device Manager. The DiCE hardware shows 'running correctly. Im just baffled by it not appearing in the USB list?
Very strange as it ran fine on the T5 a few months ago plugged in off it went. Looks like I need the update as you say!
Post 816390 by davebb on 2018-05-18 20:50:45
Hi why are you putting in 4 as the username ?
it should be admin,
Dave
Post 816391 by davebb on 2018-05-18 21:06:44
also you do not need the Dice unit to be connected to login to vida
Dave
Post 816397 by Tee5alive on 2018-05-19 12:53:16
Tried ADMIN and it faulted immediately, on the desktop screen it says the LOGIN is '4' ? I guess the last owner changed it?
Yes I understand that VIDA can be started stand alone without the Dice. Thanks Dave
Post 816402 by LeeT5 on 2018-05-20 10:22:23
[QUOTE=Tee5alive;816349] I wonder if its the SAME person selling these laptops knowing they will work for maybe 1 or 2 diags THEN totally go FUBAR??[/QUOTE]
Now that's the synical in you :cuckoo:
I'm going to speak to someone I know next week and I'll ask if you can have a 'one to one'. Cos you ain't gonna fix your issue here mate.
Jellison, have you fixed your VIDA/DICE yet or would you like help too?
Post 816403 by davebb on 2018-05-20 12:19:02
[QUOTE=Tee5alive;816397]Tried ADMIN and it faulted immediately, on the desktop screen it says the LOGIN is '4' ? I guess the last owner changed it?
Yes I understand that VIDA can be started stand alone without the Dice. Thanks Dave[/QUOTE]
Hi did you put in admin lower case ?
Dave
Post 816404 by Tee5alive on 2018-05-20 14:14:01
Thanks Lee
Yes Dave tried upper and lower case PLUS adding '4' before and after admin no joy. Usually I plug in and its straight online!
Post 816446 by Tee5alive on 2018-05-31 22:54:43
UPDATE
Deleted VIDA totally, clocked the laptop back to 2014 (the issue of VIDA) did a reinstall and loaded a patch and BINGO - WE HAVE FULL DIAGS! HOOOOYAH!
It had 'timed out' so hopefully by putting the date back it fools the program its still in date.
OP JELLISON TRY THIS METHOD! There is a tab somewhere that tells you how long you have left on the VIDA license so just put the clock back!
