Dem communication problems
Post 816006 by Mick82 on 2018-04-03 18:17:13
Hi all new to the forum. I have a 2007 xc90 d5 185 bhp with 192000 having a problem with the dem module not communicating with vida just wondering if any body else had the same problem. Also the mechanic said it could be the pump but I've tested the pump when my original module went down and it was fine run 12v to it and it fired up but could a dodgy pump prevent Vida from communicating with it any advise would be gratefully appreciated thanks in advance. Mick82 is offline
Post 816007 by Harvey on 2018-04-03 19:17:19
Remove the module and check it for water ingress , There are number of firms that wil repair them so not Volvo dealer only. and have a look at the plugs for corrosion.
Post 816008 by Mick82 on 2018-04-03 20:10:39
Hi Harvey put a new dem on it cleaned all plugs changed oil n filter checked for voltage to the pump got that powered the pump up with separate 12v supply that worked checked canbus high n low and got voltage over both pins but just won't communicate with vida
Post 816009 by davebb on 2018-04-03 20:50:15
Hi Open up the Dice unit and make shore tall the leads are plugged in, Dave
Post 816010 by Harvey on 2018-04-03 20:51:20
[QUOTE=Mick82;816008]Hi Harvey put a new dem on it cleaned all plugs changed oil n filter checked for voltage to the pump got that powered the pump up with separate 12v supply that worked checked canbus high n low and got voltage over both pins but just won't communicate with vida[/QUOTE] where did you get the new dem from ?, was it brand-new or new to the car . They are coded to the car but if you have the old unit the new one can be cloned from it. you could also unplug the pump to see if the dem comes to life . Just had a quick look fuse F27 & F23 on the REM are both good ?. Image
Post 816011 by Mick82 on 2018-04-03 21:55:21
Got a recon 1 of a guy in London all software up to date but my original unit didn't communicate either everything works on the awd it's just not communicating
Post 816012 by Mick82 on 2018-04-03 22:01:29
Both fuses are good aswell
Post 816013 by Harvey on 2018-04-03 22:02:53
whats the vida map screen look like for the dem red / grey / green ?
Post 816014 by Mick82 on 2018-04-03 22:28:56
[QUOTE=Harvey;816013]whats the vida map screen look like for the dem red / grey / green ?[/QUOTE] Not sure bud wife took it in I'm getting a Vida next week so I can look at it myself would the colour make a difference like?
Post 816015 by Ettienne on 2018-04-03 22:29:48
Where abouts are you based? I’ve got a 2006 facelift dem from our old Xc90, if you wanted to rule it out.
Post 816016 by Mick82 on 2018-04-03 22:31:05
Doncaster
Post 816017 by Mick82 on 2018-04-03 22:32:26
The dem is working I think got no anti skid message does the pump run all the time or does it just kick in when it's needed? Traction control kicks in
Post 816018 by LeeT5 on 2018-04-04 04:29:27
[QUOTE=Mick82;816006]Hi all new to the forum. I have a 2007 xc90 d5 185 bhp with 192000 having a problem with the dem module not communicating with vida just wondering if any body else had the same problem. Also the mechanic said it could be the pump but I've tested the pump when my original module went down and it was fine run 12v to it and it fired up but could a dodgy pump prevent Vida from communicating with it any advise would be gratefully appreciated thanks in advance. Mick82 is offline[/QUOTE] I'm assuming you can communicate with all other modules?? [QUOTE=Mick82;816017]The dem is working I think got no anti skid message does the pump run all the time or does it just kick in when it's needed? Traction control kicks in[/QUOTE] Traction control has nothing to do with the DEM. TRACS is controlled by the ABS module and wheel speed sensors. If the DEM pump is not running, you'll know soon enough if you try to pull away quick in the wet. The DEM pump runs all the time. Haldex Gen 4 (which is fitted to your car) has an electronic pump which is constantly running as soon as you switch on the engine. Running a MAX pressure, full time! Would help more if you could post the fault codes you have?
Post 816021 by Mick82 on 2018-04-04 06:49:58
[QUOTE=LeeT5;816018]I'm assuming you can communicate with all other modules?? Traction control has nothing to do with the DEM. TRACS is controlled by the ABS module and wheel speed sensors. If the DEM pump is not running, you'll know soon enough if you try to pull away quick in the wet. The DEM pump runs all the time. Haldex Gen 4 (which is fitted to your car) has an electronic pump which is constantly running as soon as you switch on the engine. Running a MAX pressure, full time! Would help more if you could post the fault codes you have?[/QUOTE] I haven't got any fault codes it won't communicate
Post 816022 by LeeT5 on 2018-04-04 09:48:47
Was this a sudden fault or one that occurred immediately after fitting? You do know it must have software loaded onto the DEM in order for it to communicate with the CEM?
Post 816023 by Mick82 on 2018-04-04 10:10:02
[QUOTE=LeeT5;816022]Was this a sudden fault or one that occurred immediately after fitting? You do know it must have software loaded onto the DEM in order for it to communicate with the CEM?[/QUOTE] Yes mate all software been done my original unit didn't communicate either
Post 816026 by Mick82 on 2018-04-04 16:39:41
[QUOTE=Mick82;816021]I haven't got any fault codes it won't communicate[/QUOTE] Also when u say it's nothing to do with trac when my original module went down front wheels used to spin up all time in wet but with the new dem it doesn't so surely it's got to have some sort of use within the system.
Post 816028 by LeeT5 on 2018-04-05 11:09:06
[QUOTE=Mick82;816026]Also when u say it's nothing to do with trac when my original module went down front wheels used to spin up all time in wet but with the new dem it doesn't so surely it's got to have some sort of use within the system.[/QUOTE] No. That just means the AWD is working as drive is going to the rear wheels, so no wheel spin. Wet or dry, my wheels would spin when my DEM failed.
Post 816029 by LeeT5 on 2018-04-05 11:11:08
[QUOTE=Mick82;816014]Not sure bud wife took it in I'm getting a Vida next week so I can look at it myself would the colour make a difference like?[/QUOTE] Yes the colour makes a difference. Red = Fault on that module / Recognised on CAN and communicating with VIDA/DICE. Green = Everything is OK. Grey = Module not recognised/no communication with VIDA/DICE.
Post 816221 by uqj83l on 2018-04-26 21:19:20
I’ve just had a similar issue however I had fault codes BCM0094 and CEM1A64. I replaced the DEM (£140 Volvodiagnostic London), as the pump was getting 12V. However it turned out to be a lazy intermittent pump rather than a faulty DEM. I’ve asked Volvodiagnostic to return me my DEM (which was fine) or offer me a partial refund. I’ve had no response! Charming. Good luck in getting it sorted. Both of my codes indicated there was no communication with DEM, yet DEM was fine.
Post 816223 by LeeT5 on 2018-04-27 09:10:24
Interesting. When my DEM pump failed I had fault code DEM 0006.
