6 speed gearbox
Post 812906 by modv70 on 2017-07-11 18:16:56
can somebody please tell me which volvo 6 speed gearbox will fit my 1997 volvo t5 with the easiest route i take it i will need clutch and linkage as well thanx to all that view and reply geo
Post 812907 by MoleT-5R on 2017-07-11 19:48:54
M66 fwd will do the job nicely....Oblark has one fitted in his 855 and there is a build thread on here if you have a look as the linkage does require some work from memory
Post 812909 by oblark on 2017-07-11 19:59:03
To fit the M66 gearbox to a T5 you'll need to manufacture a rear gearbox mount and modify the gear linkage on the gearbox. [ATTACH=CONFIG]31667[/ATTACH]
Post 812924 by MoleT-5R on 2017-07-12 21:22:28
ah...so you modified the levers to suit the the linkage cables Rob, I was hoping to make custom bushes that would also do the adaption when I fit my m66 awd to the v70r awd p1, I realised I'd need to make a custom cable bracket, but that doesn't look to be a big issue for me, rear mount is something I'd over looked though....!!!
Post 812926 by oblark on 2017-07-12 22:30:18
With the awd set up you won't need the rear gearbox mount you'll side to make one to fit on the side of the gearbox. [ATTACH=CONFIG]31668[/ATTACH]
Post 812950 by Ettienne on 2017-07-14 05:33:39
[QUOTE=MoleT-5R;812924]ah...so you modified the levers to suit the the linkage cables Rob, I was hoping to make custom bushes that would also do the adaption when I fit my m66 awd to the v70r awd p1, I realised I'd need to make a custom cable bracket, but that doesn't look to be a big issue for me, rear mount is something I'd over looked though....!!![/QUOTE] I'm wondering if I still have any of the m66 to 850 cable brackets anywhere, I known 100 percent I still have the jig.
Post 812961 by MoleT-5R on 2017-07-15 15:28:46
[QUOTE=Ettienne;812950]I'm wondering if I still have any of the m66 to 850 cable brackets anywhere, I known 100 percent I still have the jig.[/QUOTE] hoping to use the newer cables ...;)
