Post 810790 by Craigy t5 on 2017-03-31 21:36:40
Hi all, Is it possible to put a fanbelt from a none air-conditioned t5 engine on to an air-conditioned t5 engine leaving the air-conditioning pump/compresser still in place? What I am unsure of is will the normal heating still work? At the moment when I slide the heater control to the on position from 0,(ecc unit) i am getting squeeling from the a/c compresser and the car cuts out, it does not matter if the a/c is switched on or off it will still cut out once the heater slide switch is on, absolutly fine in the 0 position, Something is a miss with the compresser not sure what, Craig
