Battery charging
Post 810056 by SB101 on 2017-02-26 16:17:13
Is it ok to take the battery off my v70 t5 auto to charge it? Sent from my Harrier Tab from EE using Tapatalk
Post 810058 by LeeT5 on 2017-02-26 20:00:28
Why do you need to remove it? Just leave it attached to the car. Always better to charge it in situ.
Post 810060 by SB101 on 2017-02-26 20:24:50
[QUOTE=LeeT5;810058]Why do you need to remove it? Just leave it attached to the car. Always better to charge it in situ.[/QUOTE] Because it is parked in the street Sent from my Harrier Tab from EE using Tapatalk
Post 810061 by LeeT5 on 2017-02-26 20:31:47
Yes it will be ok.
Post 810062 by SB101 on 2017-02-26 20:34:03
[QUOTE=LeeT5;810061]Yes it will be ok.[/QUOTE] Will I need to reset anything when I reconnect the battery ? Sent from my Harrier Tab from EE using Tapatalk
Post 810063 by Harvey on 2017-02-26 21:04:07
Key in position 2 before refitting it tho. Not sure when you remove it tho.
Post 810064 by LeeT5 on 2017-02-26 22:20:55
No procedure for removal, but as Harvey says for fitting. You'll need to reset the clock and you may need to input radio code, depends how long the powers disconnected.
Post 810066 by SB101 on 2017-02-27 01:59:11
Cheers guys Sent from my Harrier Tab from EE using Tapatalk
