3bar map sensor for 163 2002 D5 s60
Post 809239 by davebb on 2017-01-29 18:31:52
I am looking for a 3BAR MAP sensor for my 2002 D5,as you know the denso one is fitted to the plenum top of engine not the intercooler, it is fitted with a 2.5MAP Sensor as stranded, I am going to edit the ecu map to read this 3bar sensor, Do you know of a 3bar sensor that will fit in the same mounting place, I am happy to change the plug on the loom to fit the new sensor Thanks for your Help Thanks Dave
