Post 809197 by TeamJHR on 2017-01-28 16:37:40
Hi Guys,
I have just re registered to this forum after a few years away from Volvo power for our race car, but we are now considering building a new T5 race engine but probably with a Jag supercharger instead of the turbo, I guess this has been done before so any advice will be very gratefully recieved.
Thanks in advance.
Paul.
Post 809199 by MoleT-5R on 2017-01-28 16:41:36
Colin will be along soon, he's our supercharger expert, or have a look at his build threads http://www.vpcuk.org/forums/showthread.php?53427-Volvo-850-T10-Kompressor-(Twin-engined-Project)
Post 809203 by claymore on 2017-01-28 17:01:53
Not sure of any benefits of fitting a supercharger instead of a turbo to be honest.
Post 809227 by TeamJHR on 2017-01-29 09:19:57
The thought behind it was to hopefully give a much smoother power curve, something a little different.
What would you recommend as a good engine build for a race engine ??
Post 809231 by kmb on 2017-01-29 11:16:24
Colin would (and has) put both on at the same time :)
Post 809235 by TeamJHR on 2017-01-29 15:12:36
That could be an option for us, just need a bit of advice from you guys on here as to which base engine to use, which internal mods etc as I know we would need to uprate rods etc.
Post 809236 by claymore on 2017-01-29 15:49:50
It depends a bit on how much power you're after I suppose. what car is it going in?
Post 809237 by TeamJHR on 2017-01-29 17:26:16
It is going into an Autograss Special so no limit on power, within reason obviously, but we would like good power but torque is obviously a major bonus.
We are backed by Link ECU so we can map the engine to get the best out of it.
Post 809238 by claymore on 2017-01-29 17:38:36
Ahh, ok, so there's not a space issue then. if you want more than 400 bhp then I would put some rods in a 2.3, there are gains from using a later head as I believe it flows a little better and has thinner valve stems. I still think a supercharger would be a waste of time by itself because of the parasitic losses, a good ball bearing Garrett 3076gtx would spool very quickly. there is a lot of development involved in going compound charged, it took me about two years to get the car running as I wanted it.
Post 809240 by TeamJHR on 2017-01-29 18:35:41
Thats good to know, Which engine code 2.3 engine would you suggest to start with??
Post 809427 by Wobbly Dave on 2017-02-06 13:47:35
I have a spare closed deck 2001 block which needs boring and honing. You can then fit any pistons you like. The bottom end crank ladder was repaired.
