Post 808721 by Johnboy78 on 2017-01-14 13:20:37
Does anyone know if the 20v cam cover will fit 2.0t engine in my c70,and whare would I find one? I would like to replace the one that just says Volvo on my engine cover Thanks John
You mean the earlier cam covers? Don't think they fit, Fella. From memory, the upper engine mount gets in the way and the later cover is shaped to suit. Perhaps you could butcher one to fit, but I don't think it's a straightforward swap.
Cheers Steve ,that's a bummer its not worth the hasel ,just liked the look of them over the rather boring one that's on it ,thanks anyway
A throttle cable spark plug cover won't fit a fly by wire cam cover as the engine mount as mentioned and also VVT solenoid is in the way. I describe the cam cover as the cover over the top of the cylinder head over the cams... Spark plug cover as the plastic cover over the spark plugs.
Thanks yeah Im just gony leave it if just thought it would be a cheap visual upgrade
