The R gets a reversing camera
Post 808629 by Rebel Rebel on 2017-01-10 15:30:54
It wasn't quite boxing day when I got round to this, more last week. A quick test of the camera plugged in to the iMiv (after updating the iMiv with the right firmware), and away we went routing the cabling and drilling the double skinned boot lid to get positioning of the camera spot on. Luckily in the S60 there's a few hooks in the roof of the boot to cable tie everything in to neatly, and then hide the cable away behind the boot lid trim. The main problem was getting the right size hole (about 7mm) to fix the grommet in to through the boot lid. All turned out quite neat. A quick call round to a friend at Cheshire Autobodies and the camera was firmly fixed in place with body tape and superglue. And finally just a quick thanks to Harvey for the quick sale/delivery! [ATTACH=CONFIG]31316[/ATTACH] [ATTACH=CONFIG]31317[/ATTACH] [ATTACH=CONFIG]31318[/ATTACH] [ATTACH=CONFIG]31319[/ATTACH]
Post 808633 by Harvey on 2017-01-10 17:34:51
Great to see its you got it and working :) Makes parking a Lot easier . When I had it fitted I ran the wire with the the harness from the number plate lights at the hinge .
Post 812496 by LeeT5 on 2017-06-18 08:08:22
[QUOTE=Harvey;808633]Great to see its you got it and working :) Makes parking a Lot easier . When I had it fitted I ran the wire with the the harness from the number plate lights at the hinge .[/QUOTE] So why did you remove it? I thought this was fitted to your R?
Post 812500 by Harvey on 2017-06-18 17:18:41
I fitted a different one as it's a bit smaller & no bracket so a tighter fit. Image Image Image
