Pierburg TCV
Post 807543 by st etienne on 2016-11-24 19:55:14
So can anyone recommend where I can get a HD TCV for my P2 "R" please ? Tried google but I'm not having much luck. Thanks, Etienne.
Post 807545 by stricky1967 on 2016-11-24 20:48:59
http://www.mister-auto.co.uk/en/boost-pressure-control-valve/pierburg-7-28197-16-0_g761_a0057.28197.16.0.html edit : oh sorry you said HD, don't think it's HD
Post 807546 by jamesy12345 on 2016-11-24 21:03:53
This one is it? http://m.ebay.de/itm/121976179248?_mwBanner=1
Post 807547 by Ric@rdo on 2016-11-24 21:06:07
OEM are the best!
Post 807548 by st etienne on 2016-11-24 21:24:23
Thanks guys. Sorry should of said its for a mapped car & I believe the O.E.M ones don't like the higher duty cycle from what I believe.
Post 807549 by Yosser on 2016-11-24 21:30:37
Standard are fine.
Post 807561 by kevinking2020 on 2016-11-25 22:09:03
I got mine from mister-auto http://www.mister-auto.co.uk/en/boost-pressure-control-valve/pierburg-7-22908-03-0_g761_a0057.22908.03.0.html it's gone up in price.
Post 807562 by LeeT5 on 2016-11-26 07:29:06
[QUOTE=kevinking2020;807561]I got mine from mister-auto http://www.mister-auto.co.uk/en/boost-pressure-control-valve/pierburg-7-22908-03-0_g761_a0057.22908.03.0.html it's gone up in price.[/QUOTE] It's only £25! Bargain. I'd love to know the difference between this and a stock Pierburg unit for an R and is there really any performance gain to be had? Are they electronically different, if so, how?
Post 807567 by Harvey on 2016-11-26 07:57:38
I got mine from the same place . Think it was £15 ish Image Image
Post 807569 by Tim Williams on 2016-11-26 08:11:12
The two types posted up are very slightly different, the cheaper grey one is correct for TD04s and the black one for K24s. The mounting clips are different and the TCV to actuator ports are a different size. Using the K24 TCV on a car with a TD04 and the correct size hose for the turbo can cause a boost spike due to a possible leak on the hose. When both sealed they seem to give the same boost pressure with the same TCV Duty Cycle.
Post 807570 by st etienne on 2016-11-26 09:07:33
So I am best just fitting one of the black ones then ? (if so, bugger I ordered a grey one) The TCV is for a 2006 MY R. I thought all R's had the K24 turbo ? Do the later ones like this have a TD04 then ? Many thanks, Etienne.
Post 807571 by st etienne on 2016-11-26 09:14:35
[QUOTE=Harvey;807567]I got mine from the same place . Think it was £15 ish Image Image[/QUOTE] Just out of interest Harvey did you plumb this in the same way as the standard one ? Also is your car mapped ? (I'm just been nosey really, as I've read that many threads on peoples cars I honestly can't remember who's done what) Etienne.
Post 807572 by st etienne on 2016-11-26 09:18:15
[QUOTE=LeeT5;807562]It's only £25! Bargain. I'd love to know the difference between this and a stock Pierburg unit for an R and is there really any performance gain to be had? Are they electronically different, if so, how?[/QUOTE] I was under the belief they withstand higher duty cycle better, I have no proof of this, only what I've read on various websites. Im sure one of the experts such as Tim could verify whether this is true or not ? I suppose I could just change it every to be on the safe side as I do with my MAF sensor ?
Post 807578 by Harvey on 2016-11-26 13:10:04
No map on mine. Same plug direct replacement. Have a read . http://forums.swedespeed.com/showthread.php?250881-IPD-HD-TCV-vs-Stock-TCV
Post 807581 by st etienne on 2016-11-26 13:50:41
OK then, I will get another one of these ordered then for the 2003 "R" as I fitted an IPD unit to that car (foolishly thinking it was a precautionary fix). Thanks for that Harvey, very interesting reading, I could of swore that was where I'd read about the IPD unit been the better option.
Post 807583 by Tim Williams on 2016-11-26 18:22:57
I've not done extensive testing myself with the two different types only logging when fault finding. On the car I use on track we have changed between either type several times and noticed no difference in boost and that runs over 95%TCV Duty Cycle. The grey ones do give peaky boost after about 10k miles of use the same as the black ones. All the P2Rs did have K24s, I was referring to the fitment of the grey TCV on more suitable applications for the port size. If the hose to the actuator is secure and the TCV secured then either will work fine, an IPD one will not work fine...
Post 807585 by LeeT5 on 2016-11-26 19:37:33
[QUOTE=Tim Williams;807583]I've not done extensive testing myself with the two different types only logging when fault finding. On the car I use on track we have changed between either type several times and noticed no difference in boost and that runs over 95%TCV Duty Cycle. The grey ones do give peaky boost after about 10k miles of use the same as the black ones. All the P2Rs did have K24s, I was referring to the fitment of the grey TCV on more suitable applications for the port size. If the hose to the actuator is secure and the TCV secured then either will work fine, an IPD one will not work fine...[/QUOTE] Do go on...:shhh:
Post 807589 by LeeT5 on 2016-11-26 19:57:03
I'd be willing to try another HD IPD TCV again, as unfortunately, when I had one fitted a few years ago I had lots of underlying boost issues, leaks etc that were masking any performance gains. Fitting a new stock TCV was the only way forward in diagnosing and elimination of faults. Now my car is running 100% perfect, I'd like to see if they really do make a difference. It's fair to say that a lot of ppl have fitted HD TCV's from IPD in the past, some before doing a Stage 0, and others without even realizing that they have faults or boost issues, leaks, weak components etc, etc. So it's under these circumstances that the IPD TCV would have been given a bad reputation, IMHO. Now I'm not saying they are better than a stock Pierburg TCV, but, being more mechanical, they're must be some gains to be had from using one?? Who really knows? Maybe I'll fit one and then report back!............
Post 807590 by Ric@rdo on 2016-11-26 20:11:59
I've been told by a tuner that the grey tcv delivers about 0.2-0.3bar less boost that oem at same duty cycle. Off course that this refers to my particular engine with the k24.
Post 807591 by Tim Williams on 2016-11-26 20:41:17
I've got 4 different "HD TCVs" they all give higher boost than a new standard TCV. Higher boost will usually give slightly more power in the mid range BUT if it's more boost than the maps is intended for them it's a bad thing. In most instances you have to drive in a prescribed manor to help the ECU to adapt to the incorrect operation. Some maps adapt better than others.
Post 807592 by Ric@rdo on 2016-11-26 21:06:10
I actually have a brand new oem tcv at home that I'm going to fit when I get home in a couple of weeks. I'm curious to see if it corrects the boost increase that my engines has on the mid-rpms ;)
Post 807593 by st etienne on 2016-11-26 21:09:50
Looks like I've opened a can of worms here ? I'll get a couple of standard ones to try too as there pretty cheap anyway. Thanks for the input everybody : )
Post 807798 by st etienne on 2016-12-05 19:06:45
Well here is a bit of a progress update if anyone is interested. My "Daily" was fitted with an industrial MAC valve (these were sold on another forum by the previous owner). I had noticed that at W.O.T it would spike to 18 psi then settle at 15 psi. It was also very very noisy, this was quite annoying too. I honestly can't say that this affected how the car drove though. So, I have fitted a Grey pierburg TCV that was marketed for the 996 Porsche (thanks Jamesy for the link). I fitted this last week, I trundled around for a few days after fitting as I only have a short commute to work. On Saturday I had to collect some parts so covered around 500 miles so it should have settled/adapted prior to this. The main thing I have noticed now is the car now boosts to 18 psi and stays there. I honestly can't say I can feel any difference from the extra 3 psi but it does stay consistent. I will be removing the IPD mac valve I have fitted to my other 'R' as from what has been pointed out its best to stick to the O.E.M valves. Thanks again everyone for your input, Etienne.
Post 807835 by htomi on 2016-12-06 14:01:31
Ordered the grey Pierburg 7.22908.03.0. marketed for the 996 Porsche. Let's see if it makes any difference. Currently, I'm running on the factory black OEM one. As for the MAC valve & according to Hilton's website, he won't even tune any cars equipped with MAC control valve. Also based on feedback (sweedspeed) people ran into issues with these. [I] Prerequisites: Stock TCV or upgraded Pierburg valve. (Note: A MAC control valve or equivalent is not compatible with this product. If you are using one of these valves, ensure it is replaced with a Pierburg unit prior to tuning.)[/I] https://hiltontuning.com/product/2004-s60rv70r-me7-p2/
Post 807836 by st etienne on 2016-12-06 15:12:39
I don't think it will make your car any faster, well not unless your old valve is worn out any way ? And from what Tim Williams said the Grey valves handles the slightly higher boost pressure that a mapped car has better. On another note Tim mentioned about fitment, I'm not sure if it is the fact my car had the MAC valve fitted but the hose was slightly loose so required a stronger clip to secure it to the Grey valve.
Post 807837 by LeeT5 on 2016-12-06 15:24:46
[QUOTE=st etienne;807836]I don't think it will make your car any faster, well not unless your old valve is worn out any way ? And from what Tim Williams said the Grey valves handles the slightly higher boost pressure that a mapped car has better. On another note Tim mentioned about fitment, I'm not sure if it is the fact my car had the MAC valve fitted but the hose was slightly loose so required a stronger clip to secure it to the Grey valve.[/QUOTE] Did he? Is that true? Should I get a grey valve then as mine is mapped??
Post 807838 by st etienne on 2016-12-06 16:13:50
[QUOTE=LeeT5;807837]Did he? Is that true? Should I get a grey valve then as mine is mapped??[/QUOTE] It's upto you I guess ? His comment is on the previous page.
Post 807846 by htomi on 2016-12-07 08:07:02
[QUOTE=st etienne;807836]I don't think it will make your car any faster, well not unless your old valve is worn out any way ? And from what Tim Williams said the Grey valves handles the slightly higher boost pressure that a mapped car has better. On another note Tim mentioned about fitment, I'm not sure if it is the fact my car had the MAC valve fitted but the hose was slightly loose so required a stronger clip to secure it to the Grey valve.[/QUOTE] Mine isn't mapped. It's bone stock, besides the resonator delete. The OEM TCV is more than a year old, so I don't think it's worn. I assume for the price, I can't go wrong with the grey one.
Post 807848 by st etienne on 2016-12-07 12:26:57
It's early days for me to really comment is it has only been on a week. I have a new Black valve that I purchased for my other car to replace the IPD mac valve. If I get time I will fit this and try to see if there is a difference. Like you say for the price it's not the end of the world & if you have to change it every 12 months then it is no biggy ?
Post 807851 by htomi on 2016-12-07 15:22:06
[QUOTE=st etienne;807848] Like you say for the price it's not the end of the world & if you have to change it every 12 months then it is no biggy ?[/QUOTE] Yep, I paid around €40 for the OEM valve. €28.80 for the grey one is even better in regards to the price.
Post 808339 by htomi on 2016-12-30 09:07:30
Just an update. 2wks ago installed the grey TCV. Fitment was tight, no loose connections and was working fine on short distance commute drives. Noticed very-very little improvement over the black OEM valve, however it could be easily due to this unit was new vs 1 year old one. Last weekend had a chance to do a longer trip, and then on the way home I experienced a boost spike. Came home and decided to switch back to the original unit. No more boost spike since.
