The next project volvo.
Post 807540 by Ettienne on 2016-11-24 16:17:08
I had an interesting drive yesterday picking up parts for a project car, quite local really only 900miles! From Portsmouth to north Glasgow and back lol. Best of all the a34 was closed so detoured via m25 and a3. Small clue as to the project in the pic I had made up.
Post 807541 by jimka on 2016-11-24 18:54:31
good image!
Post 807544 by jamesy12345 on 2016-11-24 19:56:08
Its not 1 & a half Volvo 480's is it
Post 807550 by Ettienne on 2016-11-25 07:50:59
[QUOTE=jimka;807541]good image![/QUOTE] I thought you'd like it
Post 807551 by Ettienne on 2016-11-25 07:54:26
[QUOTE=jamesy12345;807544]Its not 1 & a half Volvo 480's is it[/QUOTE] No I'm looking into making a proper 760 turbo intercooler, hence the trip north to collect all the stuff and more to do a 5 pot conversion.
Post 807552 by Doingitsideways on 2016-11-25 09:57:08
[QUOTE=Ettienne;807551]No I'm looking into making a proper 760 turbo intercooler, hence the trip north to collect all the stuff and more to do a 5 pot conversion.[/QUOTE] But surely you should be using a T6 lump for that artwork to be right?!
Post 807553 by Ettienne on 2016-11-25 10:22:03
[QUOTE=Doingitsideways;807552]But surely you should be using a T6 lump for that artwork to be right?![/QUOTE] Yep that's what I meant by proper �� Picked up, white block m90, 960 sump, oil pick up, linkage, mounts, waterpipes, Additionally, uprated new looking 240 anti roll bar with bushes, shorten 960 sump for 5 pot, another set of water pipes (probably haven't check them yet) another oil pick up, a V70r engine 117k and a set of brand new in box h beam rods. Enough to fit either 5 or 6 pot to a 240 or 740 if I had another box I could do two conversions.
Post 814964 by V70dan on 2017-12-13 19:57:15
It is some thing that won't work with you'll need to remove and fabricate new engine mounts and you may bump into difficulty with gear box yes six is better but damm that's a lot of work for one extra cylinder and twin turbo system Hope it works tho that will be a machine ����
