Post 806257 by edde on 2016-10-17 09:52:40
So the discs and pads need doing so I thought why not upgrade them at the same time.
I have the 286 discs currently, and from reading around it seems I only need to get the 305 carriers, along with the larger discs obviously.
I was just wondering if anything else is required, like larger dust shields to accommodate the bigger discs?
Also I've read conflicting information regarding needing new hoses, and can anyone confirm that, as well as whether this setup won't foul on the Tethys alloys.
Thanks in advance :)
Post 806258 by Ettienne on 2016-10-17 10:06:46
Why not go for 336s from an xc90? Very easy to fit and they fit under17s, make a massive difference and cheap to buy.
Just need to drill 14mm clearance hole in hubs.
Post 806267 by edde on 2016-10-17 13:17:53
As impressive as that xc90 setup is, it's probably overkill for my needs lol.
Plus the price difference between going to 305 vs 336, well I could put that money towards renovating the original 180k suspension lol.
Post 806268 by stephenevans99 on 2016-10-17 13:43:02
[QUOTE=edde;806267]As impressive as that xc90 setup is, it's probably overkill for my needs lol.
Plus the price difference between going to 305 vs 336, well I could put that money towards renovating the original 180k suspension lol.[/QUOTE]
Totally understandable... even though it's considered a budget upgrade, the overall cost still isn't pocket money.
[QUOTE=edde;806257]
Thanks in advance :)[/QUOTE]
The standard dust shields are fine as are the standard brake hoses. The 305mm setup will fit under Tethys without any issue whatsover.
Post 806276 by edde on 2016-10-17 18:16:56
Thanks for the confirmation, as well as putting bad ideas in my head lol.
As much as I love the car, I can't let myself get in too deep beyond required maintenance and repair, along with a little improvement here and there.
Now if she were a t5 or a slightly younger estate model I might be tempted to go that bit further, however I'm just trying to keep her going for now lol.
