Stc+Heated mirrors/window problem
Post 806197 by MaxiSNK on 2016-10-15 09:08:06
These switches don't work the stc when pressing the button no light comes up on the dash, and the heated mirrors/back window button doesn't light up when pressed either which is obviously a bit of a problem as I'm an early starter for work. I can't see it being a problem with the actual switches is there anything else I can look at I.e fuse wise? Can anyone shed any experience with this problem before?
Post 808094 by Johnboy78 on 2016-12-18 23:19:32
Unfortunately i can't shed any light ,but would be interested in solution mines works on rear window and pas mirror but not drivers side !
Post 808105 by Doingitsideways on 2016-12-19 21:02:21
Can't help with OP's problem, but Johnboy - you'll probably find the heeting element has died on your D/S mirror. New glass and it'll be sorted.
Post 808129 by Johnboy78 on 2016-12-21 08:54:35
Thanks Steve ,much appreciated mate
