Ets/engine management light
Post 805964 by MaxiSNK on 2016-10-05 19:16:07
ETS light came on this morning ticking over causes it to rev fluctuating between 1000/1500 rpm but this evening the engine management light has came on and thencarnwont go about 1.5k revs. Any ideas? Volvo C70 T5 2003
Post 805970 by phil67 on 2016-10-05 22:15:13
Have you managed to scan it for codes? Check your vacuum pipes for problems, could be throttle body, Maf, but really need the fault code to help pin point the issue.
Post 805972 by MaxiSNK on 2016-10-05 22:23:43
[QUOTE=phil67;805970]Have you managed to scan it for codes? Check your vacuum pipes for problems, could be throttle body, Maf, but really need the fault code to help pin point the issue.[/QUOTE] thsnks for the reply, I'll try get her to a garage soon to get the codes read
