NEW HT LEADS SEEM SHORT - Anyone else had the same issue?
Post 804904 by Wheelspinwardrobe on 2016-09-05 19:53:31
Hay Everyone... Just treated the 850 to some new HT leads, Dizzy, rotor, genuine plugs and new coil.... My question is this: My new OE QUALITY leads seem very tight on cyl 1,2, and 3 (shortest 3) they do only just reach but I feel put a big unnecessary strain on the leads, they seem to measure up the same as the Volvo originals and the New dizzy is much the same as the original bosch one, I triple checked everything. I'm a little confused. Anyone had same problem.... Thanks Phill
Post 804905 by kmb on 2016-09-05 21:22:44
Have you got the Dizzy cap in the same location (it may only fit in one orientation)? I recently replaced the same three things and mine fitted perfectly... using Bosch parts throughout. Other option will be the HT lead routing through the cover gap on the right hand side, maybe it's not direct and they are twisted etc.
Post 804906 by Wheelspinwardrobe on 2016-09-05 21:36:56
[QUOTE=kmb;804905]Have you got the Dizzy cap in the same location (it may only fit in one orientation)? I recently replaced the same three things and mine fitted perfectly... using Bosch parts throughout. Other option will be the HT lead routing through the cover gap on the right hand side, maybe it's not direct and they are twisted etc.[/QUOTE] I will try rotating cap tomorrow morning ;) thanks - will let you know!
Post 804907 by Wheelspinwardrobe on 2016-09-05 21:37:39
It is how it was when I brought car but will adjust!
Post 804908 by kmb on 2016-09-05 21:58:43
I think it might only locate in one place, but I could be wrong... worth checking the lead routing first ;) Good luck!
Post 804909 by Orca2 on 2016-09-05 22:20:04
Unless distributor caps have changed significantly since I last had one , it will only fit one way , and you can't "adjust "it without altering the ignition timing . Or am I missing something?
Post 804914 by Tim Williams on 2016-09-06 08:14:20
The leads need to be orientated correctly for the standard Bougicord leads to fit. I have found time and time again that ALL other after market leads don't fit correctly, they may push on but arch causing the coils or caps to burn out after a while causing a misfire.
Post 804918 by LeeT5 on 2016-09-06 10:09:06
[QUOTE=Wheelspinwardrobe;804904]Hay Everyone... Just treated the 850 to some new HT leads, Dizzy, rotor, genuine plugs and new coil.... My question is this: My new OE QUALITY leads seem very tight on cyl 1,2, and 3 (shortest 3) they do only just reach but I feel put a big unnecessary strain on the leads, they seem to measure up the same as the Volvo originals and the New dizzy is much the same as the original bosch one, I triple checked everything. I'm a little confused. Anyone had same problem.... Thanks Phill[/QUOTE] Clearly they're not! [QUOTE=Tim Williams;804914]The leads need to be orientated correctly for the standard Bougicord leads to fit. I have found time and time again that ALL other after market leads don't fit correctly, they may push on but arch causing the coils or caps to burn out after a while causing a misfire.[/QUOTE] What Tim said is spot on. You should take the HT leads back and buy a genuine set from Volvo. Aftermarket HT leads, as Tim says, are often shockingly bad and the fitment is never perfect. I've experienced this problem myself (during my 850 T5 ownership days) and I see it all too often at the roadside. Genuine HT leads are good for 100k and fit perfectly whereas, pattern parts are not! They might well be triple the price but you'll only buy them once and they won't let you down or fall off or break down through cheap quality. As the old saying goes....buy cheap, buy twice!
Post 804928 by Tim Williams on 2016-09-06 13:39:35
You can buy the correct leads from PFV for about £50 delivered. Don't be tempted with the uprated ones. The difference between the Bougicord lead set and the set from Volvo is a small bit of spiral wrap on the could lead and about £80. To see the difference you can look at Neil's 850 as that has the far more expensive coil lead lol.
Post 804931 by kmb on 2016-09-06 17:23:33
As an added note - I bought Bosch ones (rather than Bougicord), they were the correct length and fitment. I bought all Bosch items i.e. rotor arm, dizzy cap and leads, seemed easier to get all at once and total delivered cost was below €100. did consider the Bougicord but it would have involved a second order, so stuck with one place.
