c70 2.3 t5.......odd cold start
Post 803374 by welsh-t5 on 2016-07-25 18:58:30
right on cold start the car always starts first time with no issues . after the choke cuts out the revs drop to almost stall then back to normal for about 1 minute up and down then everything is fine and dandy......if you try to drive whilst its dicking around there is no power but once its settled down its bang on .......head scratching.......
Post 803375 by Shinsplintz 101 on 2016-07-25 19:50:24
Get codes read - main culprits will probably be Idle control valve or MAF from the symptoms you describe, or even a dicky O2 sensor, possibly. But could also be an number of other minor factors adding up to rough running. Start with the codes & take it from there. Good luck, cheers, Morgan
Post 803377 by welsh-t5 on 2016-07-25 20:18:31
i had the codes read last week and nothing came up.....as i said the rough idle only lasts for a minute then everything is hunky dory
Post 803384 by Shinsplintz 101 on 2016-07-26 07:33:25
If the MAF or O2 aren't throwing codes then it's likely to be the ICV - you didn't mention what year the car is, or service history. One of my old 850 t5s developed similar symptoms, again no codes, but new plugs & cleaning out the ICV sorted the issue.
Post 803387 by Biff on 2016-07-26 11:13:15
Carb cleaner & ain air line sorted my R with this issue
Post 803395 by welsh-t5 on 2016-07-26 17:15:31
sorry its a 2001 model......where is the icv located on this engine
Post 803434 by Dream3r on 2016-07-27 22:50:34
Codes but sounds like a vac leak or maf issue
Post 803629 by welsh-t5 on 2016-08-01 20:41:44
Sorted now it was a vac leak
