Post 801364 by Baj on 2016-05-25 12:01:56
http://www.ebay.co.uk/itm/1994-VOLVO-850-T5R-MANUAL-ESTATE-BLACK-/131819134377?hash=item1eb1085da9:g:zC4AAOSwqbZXEUYU
I am toying with the idea of making enquiries into this. Its been for sale for a while which is not a great sign.
Just wondering if it belongs to someone here or it's passed through someones possession at some point. It's 100 miles away so Prior Preparation etc
Reg - M ?56 MTF
Post 801366 by Timo. on 2016-05-25 15:06:45
Doesn't look/sound too bad....
Don't like the black wheels.
Post 801367 by jamesy12345 on 2016-05-25 15:29:15
Been off the road for a while according to MOT history site, which may not be a big deal as long as sufficient work has been done on it..took a while to fix the 'oil leak' so maybe worth checking out what that was (is??)
[I]
Check the MOT history of a vehicle
Registration number: M656 ???
Vehicle make: VOLVO
Vehicle model: 850
Date first used: 8 December 1994
Fuel type: Petrol
Colour: Black
MOT history of this vehicle
Test date: 4 July 2015
Expiry date: 3 July 2016
Test Result: Pass
Odometer reading: 147,518 miles
MOT test number: 1697 0568 5151
Test date: 4 October 2011
Expiry date: 3 October 2012
Test Result: Pass
Odometer reading: 139,466 miles
MOT test number: 5670 7747 1215
Test date: 3 April 2010
Test Result: Fail
Odometer reading: 127,119 miles
MOT test number: 1339 6379 0054
Reason(s) for failure:
Registration plate lamp not working (1.1.5c)
Advisory notice item(s):
Oil leak
Expiry date: 2 April 2011
Test Result: Pass
MOT test number: 4532 3309 0054
Oil leak
Test date: 11 December 2008
Expiry date: 17 December 2009
Test Result: Pass
Odometer reading: 121,864 miles
MOT test number: 5440 3604 8365
Rear nuber plate poor
Test date: 10 December 2008
Test Result: Fail
MOT test number: 1201 8584 8351
Nearside Front Suspension arm has excessive play in a ball joint (2.4.G.2)
Offside Front Suspension arm has excessive play in a ball joint (2.4.G.2)
Nearside Front Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Side repeater incorrect colour (1.4.A.2f)
Offside Rear Direction indicators incorrect colour (1.4.A.2f)
Test date: 18 December 2007
Expiry date: 17 December 2008
Test Result: Pass
Odometer reading: 116,810 miles
MOT test number: 1412 3205 7308
Offside Rear Direction indicator slightly discoloured (1.4.A.2f)
Offside Side repeater slightly discoloured (1.4.A.2f)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Slight play in steering rack
Oil leak
eml on
air bag light on
Test date: 11 December 2006
Expiry date: 10 December 2007
Test Result: Pass
Odometer reading: 112,851 miles
MOT test number: 5229 7514 6308
Test date: 7 April 2006
Expiry date: 6 April 2007
Test Result: Pass
Odometer reading: 111,003 miles
MOT test number: 4628 0769 6051
Test date: 6 April 2006
Test Result: Fail
Odometer reading: 110,972 miles
MOT test number: 2023 7699 6000
Nearside Front constant velocity joint gaiter split (2.5.C.1a)
oil leak[/I]
Post 801369 by Doingitsideways on 2016-05-25 16:23:01
Hope it's not been parked on that grass for too long.
Volvos stand up to it better than most, but not for ever.
Post 801371 by Baj on 2016-05-25 17:02:48
Oil leak is suitably vague.
What about the airbag light? Cheap dodgy connection or expensive replacement?
