Billstein B6 - 2004 V70 R
Post 801281 by htomi on 2016-05-24 08:24:37
Just noticed my front right strut is leaking. It is the original Monroe, so it was expected at some stage. Most likely, I'm planning to go with the Billstein B6 (BILSTEIN, 35-052210) and complete the modification seen on the US forum. Ex extract the sensor from the Monroe to foul the 4C system. Based on the description found, the 35-052210 fits the 2004 V70 T5 and 2004 V70 2.5 T, but before making a hole in my wallet, I want to be sure that's the right one for my 04'VR and it is bolt on. The car shall remain on stock springs and only the front struts (2) will be replaced. Comments are welcome.
Post 801285 by Redbrick on 2016-05-24 09:05:48
When a good working system is so capable why would you want to do this and not just replace the front shocks with OEM Monroe?
Post 801292 by htomi on 2016-05-24 10:03:05
In my opinion, Billsteins are far better than Monroes. The only disadvantage of this, the 4C has to be hacked by extracting the sensor from the old one, which is not an issue as the drivers side is already leaking. Now, as I got deeper in this, found the Monroe C2501 brand new, for 230 EUR inc shipping, locally from Ireland. That's more less the same price for the B6 but no hacking required, just plug an play. Cross referenced the OE 30683703 and its matching up. As far as I know the OEM ( which is sold by Volvo for a nightmare price) was developed by OHLINS and Monroe struts were used. So this got me thinking to stick to the Monroe, due to less hassle with the installation.
Post 801294 by Harvey on 2016-05-24 10:33:59
I know there was a supply issue from Monroe but they were due to run a batch off soon.
Post 801295 by jamesy12345 on 2016-05-24 10:38:55
Some links in the thread below for places to buy Monroe stuff http://www.vpcuk.org/forums/showthread.php?61520-V70R-4c-like-for-like-replacement&highlight=monroe+shocks
Post 801296 by htomi on 2016-05-24 10:51:16
Thanks guys! Just got off the phone with the local dealership where my buddy confirmed the Monroe C2501 is the part number for the R front strut. He suggested too, to stick to the Monroe due to less complication with the install.
Post 801297 by htomi on 2016-05-24 11:08:00
Ordered the Monroe for €225/strut inc shipping.
Post 801298 by LeeT5 on 2016-05-24 11:31:28
Going from worn out, knackered stock shocks to OE new ones was night and day! The feel of your worn shocks compared to new ones will be huge. I strongly advise that you stick with OE shocks on the stock springs. For the extra, considerably small cost, it's worth buying new springs as well, They sag over time. I think that mixing new Bilsteins B6 with OE Monroes on the rear, is a recipe for disaster. Either fit B6's all round or Monroes, not mix.
Post 801302 by htomi on 2016-05-24 12:07:11
Thanks Lee! Understand your idea about the springs, but I'm afraid, I'll have to skip on those for now. Updated the thread title.
Post 801313 by Ettienne on 2016-05-24 17:57:18
No need to extract anything it's just a resistor to fool the 4c put in the plug. Last time I saw them they were £300-350 for a set
Post 801315 by Ettienne on 2016-05-24 18:03:43
"Really easy actually. You have to mount the existing suspension accelerometers to your non4c or aftermarket replacements. As for the electrical side of things, each shock/strut has a 2-wire harness coming out of it... Cut the harness and in the shock's place, solder in or use butt connectors to install a simple 8 ohm 20 watt ceramic resistor. And there you go!"
Post 801316 by Harvey on 2016-05-24 18:31:12
Have a read of the thread, not just one paragraph.. http://forums.swedespeed.com/showthread.php?164573-Tricking-the-4C-(Using-non-4C-amp-coilover-shocks-struts)
Post 801317 by Harvey on 2016-05-24 18:32:42
[QUOTE=Ettienne;801315]"Really easy actually. You have to mount the existing suspension accelerometers to your non4c or aftermarket replacements. As for the electrical side of things, each shock/strut has a 2-wire harness coming out of it... Cut the harness and in the shock's place, solder in or use butt connectors to install a simple 8 ohm 20 watt ceramic resistor. And there you go!"[/QUOTE] Have a read of the full thread not just one paragraph , it's worth it.. http://forums.swedespeed.com/showthread.php?164573-Tricking-the-4C-(Using-non-4C-amp-coilover-shocks-struts)
Post 801330 by Ettienne on 2016-05-24 19:51:16
I only posted up the relevant info to fool the 4c, I kind of thought he'd made his mind up.
Post 801359 by htomi on 2016-05-25 09:31:57
[QUOTE=Ettienne;801313]No need to extract anything it's just a resistor to fool the 4c put in the plug. Last time I saw them they were £300-350 for a set[/QUOTE] Yes, I've seen that, however the resistors are working only up to the 04 models. According to the info from the States folks, 05 and above cannot be fouled that way, in that case the sensor extract is the way to go with. I've seen the pictures on the US forum and kinda liked the idea + nice & clean setup. http://forums.swedespeed.com/showthread.php?208080-Four-C-strut-shock-delete-replaced-with-HD-BILSTEIN
Post 801363 by htomi on 2016-05-25 11:38:11
As said above, my first intention was to go with the B6, mainly because we had Billsteins in the missis Mini R50 once the factory ones were close to their end of life. (oh man, what a difference it was! the new factory Mini struts doesn't even come close to the Billstein) + the good reviews about the B6. Finally I gave up the idea primarily due to the minimum price difference, secondary the car remains on the factory set and lastly no hacking required.
Post 801393 by stricky1967 on 2016-05-25 22:19:37
Replaced all mine a few months ago , last MOT pointed out I had a 'misting' front, so took the plunge and got new front and rears Monroes C2501 fronts and C1501 rears, costs were approx £300 per pair , so around £600 total. made a big difference, often have it fully loaded with the us the 4 kids and dog. Didn't change the springs though they looked OK.
Post 802039 by BigGreg on 2016-06-13 20:31:39
Did your struts turn up. Cracking price?????
Post 802051 by htomi on 2016-06-14 10:58:59
Update. My order for the Monroes got cancelled due to no availability. I did search for 2 days, the only option I could find was to order them from the States and pay customs duty or buy the Volvo labeled for nearly 600 EUR for 1 strut. So, I said f*** this: 1. I'm not a millionaire to pay 1200 EUR for a pair of struts. Its a stupid price ... 2. Bilstein is way better quality than Monroe. 3. I needed my car back on the road Order the 2 B6s (35-052210) from skandix.de for 484 EUR inc shipping. Got installed both during the past Saturday. We've been able to extract the 4C sensors from the old one by cutting (round) the strut pipe at the bottom and then unscrew the sensor with its housing. So, no soldering was required. Placed the sensors inside the engine bay and plugged back. No error messages. My current setup as follows: B6 + stock springs. The rest of the front suspension is new (less than 6k miles). Strut bearings, bearing plate, control arms, ball joints, tie rods are all Lemforder. First impression: drove home from the garage, 50 km, 75% dual carriage - highway kinda road and 25% back road (very bumpy, uneven surface, full with potholes). Rears are still the factory ones, with no modification whatsoever. Setting = Sport. The front is well seated on both type of roads. It feels between comfort and sport mode, but more towards to the sport firmness. I would say its a hairline softer than the sport setting. Riding on the good quality road surface, the difference is hardly noticeable, compared to the rear. Once reached the bumpy part, the car turned into something amazing! It seems these Bilsteins just wants more & more bumps and speed! No more bouncing, crashes, hip-hops, just smooth and same time firm/sporty ride. Rears are still tight and firm, but definitely, I can feel more hops and bouncing over the bumps compared to the front. On Sunday, we went for biking and drove the car with the new setup for 150 miles. 40% dual carriage and 60% back road. Setting= Sport. Same results, the car feels well seated in all 4 corners, no matter the road quality. I drove like a 'hooligan' on the back roads as my other half said. No wonder :dgrin: the B6s just inspiring me for more speed. Cornering is laser precise and as said no more bouncing, crashes, hops, just a firm sporty ride. Conclusion: I'm 110% happy with the B6s , but in case if someone is looking for a firmer ride, go for the (T5) B8 and use lowering springs. It will be between the factory sport and advanced. Alternatively if the budget is there, then KW coilovers + lowering springs. I'll wait till the rear Monroes going to be shot and go for the rear B6 (24-018050). Kindly note, currently nobody makes any straight swap alternative for the rear Monroe C1501. The above listed rear (24-018050) is originally for a Jaguar. The exact same has been successfully used & still in use on a S60R with minor modification. I'll attempt the same once my rears are gone. Posted the same and more you can find/read on the US (sweedspeed) forum. http://forums.swedespeed.com/showthread.php?208080-Four-C-strut-shock-delete-replaced-with-HD-BILSTEIN/page6
Post 810773 by htomi on 2017-03-30 20:37:45
Thread resurrection. First of all, I don't want start a 'thread war' or to convince anybody to swap over to Bilstein. It is - at least for me - just an alternative over the 'gold' priced Monroe struts. As you may aware - from sweedspeed.com - installing a rear B6 (24-018050) shock absorbers require some skills, proper tools and access to a machine shop which not all of us have to be able to overcome the missing spring perches problem. A newer and simplified method discovered by an sspeed member, which is based on the Mazda Miata world practice to fit Bilsteins on the MX-5s. In a nutshell: A 3rd party adjustable coil-over spring sleeve kit can be used and then a clip grove to be cut into the Bilstein shock housing. For this modification, the lower end of the factory spring also needs to be flattened to create similar design to the coil-over springs. Additionally as mentioned above, the 4C sensor has to be removed from the Monroe and plugged back to avoid limp mode DTCs and retain the C/S/A mode functionality without the shock stiffening. (which IMHO the B6/B8 won't require anyway) So, I've reached out to Bilstein HQ to see what solutions they can offer 'off the shelf' and move this project to the next level. Today I've received an email from them with a good news! Copied the information from the email I have: "We have two options: We can offer 2 dampers for you, build as prototypes: Based on 24-018050, with circlip and springplate, setting as you would like to have. 176 Euro plus tax, plus shipping per piece. Or we create a new part-no, if we have more than 10 quantities. You can order them as often as you want, price based on quantities, of course cheaper than 176 euro. Delivery time: 6 – 8 weeks." Now, I'd like to see if we can come up with more than 10 orders (globally) to aim for the second option = new part-no which would be beneficial for the greater community. So please add your nick name to this topic if you're interested and also 100% committed to buy the product, once available. I'd prefer to close this off by EOD 7th of Apr 2017. Thanks! htomi
Post 810777 by htomi on 2017-03-31 08:38:43
So far 2 orders. Again,please add your nick name to this topic if you're interested.
Post 810783 by Harvey on 2017-03-31 11:08:08
Might be a idea to change the title to S60R & V70R .and drop the year. Good they will offer this tho.
Post 810785 by htomi on 2017-03-31 14:46:44
Thanks Harvey! Perhaps I'm blind, but cannot see the option to be able to change the thread title....so might going to post a new thread and add the relevant information.
Post 810787 by Harvey on 2017-03-31 19:15:51
[QUOTE=htomi;810785]Thanks Harvey! Perhaps I'm blind, but cannot see the option to be able to change the thread title....so might going to post a new thread and add the relevant information.[/QUOTE] Only a moderator can but if you ask nicely sure they will. .:)
