Post 62310 by scott t5 on 2005-12-04 15:16:04
hello all for all of u that have dump valve's fitted...
got forged dump valve and kit but no instructions on how 2 fit i sort of attemped it but where i think the valve pipe goes i got my idle control valve on the old pipe(going in2 throttle butterfly) i wanted 2 know what is done with this pipe do u leave it 2 breath on its own or u do u cut it in somewhere i'm confused so any help would be excellent many thanks :)
Post 62312 by fraz13 on 2005-12-04 15:24:54
Hi mate
Heres where I have ma DV fitted....
The pipe that comes out the top of the DV gets put into a Y piece and spliced into the pipe going to the Recirc DV
If your removing the Recirc DV then just fit the pipe into the inlet manifold where the pipe for the DV was...
Hope this helps ;)
Post 62314 by scott t5 on 2005-12-04 15:31:15
my pipes dont go round the engine it goes over the top.. and on the throttle body i got an idle control valve which is on the orginal pipe but what i got with my kit dont have a fitment for it..... so i think my fitting kit is wrong maybe???????? :slap:
Post 62315 by fraz13 on 2005-12-04 15:40:32
So you got an early '94 850?
Im sure I've seen 1 with a DV on the top on that pipe.....
Post 62334 by spesh on 2005-12-04 16:22:25
best thing you can do is, cut the pipe from the top of the cooler and put a T-bit in with the dump valve off that, ive got a 94 850, and thats what i done.
Post 62348 by scott t5 on 2005-12-04 16:48:06
ok cheers where can i get the t part from ???? i was trying 2 up load a pic but it wont let me :nutkick:
Post 62351 by spesh on 2005-12-04 16:52:39
[QUOTE=scott t5]ok cheers where can i get the t part from ???? i was trying 2 up load a pic but it wont let me :nutkick:[/QUOTE]
I paid £20 for mine, was cheaper than halfords, i got mine from a motor factors, but i guess you can get them in most car shops. eg halfords, motor world etc...
Ive only got pics of my new set up, and i guess they wont be anygood for you lol,
Post 62352 by scott t5 on 2005-12-04 16:54:32
ok cheers guys i'll give them a go
