Post 798531 by ChrisB on 2016-03-23 21:09:59
Hi Guys, Not been here for yonks as nothing has gone wrong apart from losing AWD, and that's been sorted now, thanks to Voltec Indy in Hull. Need some replacement brake pads front and rear but cannot find any relevant size spec in the handbook and my local Andrew Page asked me if I knew the disc diameter front and rear which of course I don't. Apparently there is a 15/16/or 17 inch brake system. The last ones I bought were from Wanapart but I understand they have now been taken over so not looked there. Any help would be appreciated.
Cheers Chris B.
Post 798533 by Shinsplintz 101 on 2016-03-23 21:38:42
Pretty sure the R has a 330mm disc. Worst case - get a wheel off & measure the disc on the car. Probably the safest bet if your unsure.
Post 798606 by htomi on 2016-03-25 09:57:48
330mm vented disc. ( no groove- no drill) Whatever brand you choose, select the 'Brembo' version. I would recommend to stick with OEM if you don't do serious track days. Also just go with the OEM break pads.
Post 798665 by ChrisB on 2016-03-26 22:20:33
Hi Guys, thanks for your help, I guess i was tryng to avoid pulling a wheel off and measuring the discs myself. I am getting old now and can't roll around the floor under a car like I used to.. cheers.
Post 798676 by LeeT5 on 2016-03-27 13:30:42
They are 332mm front and rear to be exact, but commonly they are 330mm front/330mm rear.
