T5 06 Engine Rebuild
Post 798046 by sanj on 2016-03-14 08:11:24
Hi, I currently have another thread open "Mysterious Coolent Leak", but rather then corrupt that with talk of engine rebuilds I thought I'd start this one. I'm probably getting ahead of my self here, until I find out the cause of my coolent issue... but I wanted to no if anyone has any guides on doing a engine rebuild for a T5 06 and if anyone can advise on how much it would cost to get someone to do and if they know anyone, I'm based in Birmingham. Cheers
Post 798114 by sanj on 2016-03-15 12:29:15
seriously no replies...
Post 798117 by jamesy12345 on 2016-03-15 14:31:41
I've had engine work done by Shemtek in Nottingham, can recommend him. Tim Williams is also in that area although I've never used him directly he's done work on 2 cars I've owned & has a very good reputation Either that or break out the Haynes manual!!!
Post 798120 by Tim Williams on 2016-03-15 15:19:42
To do a refresh, bearings, water pump, cam belt kit, piston rings, stem seals and valve clearances the parts come to about £1000. I wouldn't advise rebuilding an engine that has an undiagnosed problem.
Post 798164 by LeeT5 on 2016-03-16 10:42:29
[QUOTE=Tim Williams;798120]To do a refresh, bearings, water pump, cam belt kit, piston rings, stem seals and valve clearances the parts come to about £1000. I wouldn't advise rebuilding an engine that has an undiagnosed problem.[/QUOTE] Wise words!
