Post 797228 by AAN on 2016-02-25 13:23:06
I am going to do the manual conversion to my R and I wanted to buy some bushes for the gear cables and the set I have seem worn, I have seen on some posts that people use the mr2 bush kits my question is am I looking at the right set in this picture or is there others I can buy any help would be great many thanks
Post 797235 by JeanPete on 2016-02-25 17:31:59
I personally used some spherical shifter bushing kit designed by CRW garage for MR2 : http://www.mr2.com/forums/threads/88574-Spherical-shifter-bushing-kit
It's different stuff but size may be the same. Then this was quite tight though, but it didnt matter as mines were made to move on their center.
Post 797239 by MoleT-5R on 2016-02-25 19:16:14
It is also possible to use proper bearing in the cable ends as Claymore has on his 850 http://www.ebay.co.uk/itm/200709759794?_trksid=p2060353.m2749.l2649&var=500563519130&ssPageName=STRK%3AMEBIDX%3AIT will just depend on the size of the cable ends on your model
Post 797413 by AAN on 2016-02-28 08:42:28
Great advice thanks will be measuring them up later :D
Post 797418 by MoleT-5R on 2016-02-28 10:25:40
these where my custom made ones, but tbh it's a lot of faff as the one's Colin's used are dirty cheap and off the shelf, but I do like to make stuff for my car.
Post 797419 by kmb on 2016-02-28 10:49:25
Mine are also identical to those pictured by Mole, they do make a nice difference to the directness of the gear change :)
I did the same on my Rev 3 MR2 Turbo, but with the ebay kit linked, similar affect.
