Front caliper mounts
Post 62023 by fireclown on 2005-12-03 13:25:45
Hi. i am after some front caliper brackets to fit my 96 t5. want to take my brakes from 280 to 302. just thought id ask. cheers. :remybussi
Post 62030 by 94 Btcc estate replica on 2005-12-03 13:45:59
heres a thread for you... Its new stuff http://performancedirect.potn.co.uk/c2918_3422_3800_5955.htm you might want to consider at least! 310mm if you wanna see a real visual differance. a 300mm/22 kit is £445 pounds (2x discs 2x brackets, nut n bits n bobs) a 310mm/28 kit is £485 pounds (same) ed
Post 62034 by Al115 on 2005-12-03 14:07:23
So why would anyone buy the 300s? to fit behind 16"s?
Post 62040 by 94 Btcc estate replica on 2005-12-03 15:15:43
i know, for extra 40 pounds. but if ya wheel diameter is too small or what ever, then i guess they are only supplyin choice.
Post 62160 by fireclown on 2005-12-04 00:33:57
[QUOTE=Al115]So why would anyone buy the 300s? to fit behind 16"s?[/QUOTE] i got 18"s m8
Post 62231 by 94 Btcc estate replica on 2005-12-04 11:33:45
if ya look on the link i put on previously, there is a option for 325mm discs..you gota call for a price, BUT, either way they are gonna HALF the price of the excellent AP racing 325mm kit!, then what you could do is get top quality paint for your origanal calipers and paint them to look like the AP or whatever!..so you could then have a AP looky likey!! (I KNOW this might be going over your intial budget..but you only buy a complete set of front brakes once..do you see what i mean??) :) ed
Post 62241 by fireclown on 2005-12-04 11:54:28
Thanks for the replys Ed. it is a bit over my budget as i need other stuff for my car. but i shall bear these in mind when the rest of my spending is out of the way. cheers.
Post 62251 by gazjacko on 2005-12-04 12:11:37
See if you can find a friendly Volvo Main agent who'll take the old brackets as exchange then the price is not too bad for genuine bits. GSF will do exchange Calipers for £65 you could paint up before you fit, and they list plain 302mm discs. Remember you'll need different hoses too (Goodridge do a C70 kit that's suitable)
Post 62252 by 94 Btcc estate replica on 2005-12-04 12:14:53
[QUOTE=fireclown]Thanks for the replys Ed. it is a bit over my budget as i need other stuff for my car. but i shall bear these in mind when the rest of my spending is out of the way. cheers.[/QUOTE] no problem.
Post 62508 by Wobbly Dave on 2005-12-05 00:33:06
Have some on salvage from my ex-C70
