IPD TCV & Powerflex top mount
Post 790147 by expolicev70t5 on 2015-11-06 09:49:27
I've just bought the above items for my car but have a couple of queries. 1. With the powerflex engine top mount it came with some lubrication, I seem to remember reading on the forum about not applying this but cant find the thread where its mentioned, can anyone give me some further feed back. 2. Just bought IPD TCV as my standard one is goosed, in the instructions it state about running at half boost and moderately accelerating etc, however I don't have a boost gage fitted in my car can anyone give me some layman's terms on setting it up as I'm not sure about what my car should be boosting to even if I did have a boost gage. Thanks in advance Paul
Post 791882 by LeeT5 on 2015-11-23 23:15:50
The TCV is just an actuator. The ecu will learn very quickly. Just drive the car normally until warmed up then give it a few hard WOT pulls in 2nd 3rd and 4th gears ensuring you decelerate to a stop and idle for a minute or two. You'll then need to switch off for 10 minutes and then drive the car normally. That's it!
Post 791893 by LeeT5 on 2015-11-24 08:12:20
[QUOTE=expolicev70t5;790147]I've just bought the above items for my car but have a couple of queries. 1. With the powerflex engine top mount it came with some lubrication, I seem to remember reading on the forum about not applying this but cant find the thread where its mentioned, can anyone give me some further feed back. 2. Just bought IPD TCV as my standard one is goosed, in the instructions it state about running at half boost and moderately accelerating etc, however I don't have a boost gage fitted in my car can anyone give me some layman's terms on setting it up as I'm not sure about what my car should be boosting to even if I did have a boost gage. Thanks in advance Paul[/QUOTE] I applied the lube to mine and it absolutely fine 3 yrs running.
Post 791921 by Ric@rdo on 2015-11-24 11:21:15
Mine didn't last more than 48hrs... :( Image Have no idea why it happened. The 3 engine mounts are brand new. Will be replacing it with a SuperPro round mount.
Post 791923 by LeeT5 on 2015-11-24 13:00:57
Do you have a link to the super pro mount?
Post 791932 by Ric@rdo on 2015-11-24 14:49:23
Sure. http://www.superpro.com.au/find/superpro-suspension-parts-and-poly-bushings-for-volvo-v70-sw-2000-2007-/cid-999501624
Post 791933 by LeeT5 on 2015-11-24 15:08:43
Thanks. Christ....2 hours figment time!! That's obviously after 5 cans of fosters! Lol.
Post 791975 by LeeT5 on 2015-11-25 08:05:18
[QUOTE=Ric@rdo;791921]Mine didn't last more than 48hrs... :( Image Have no idea why it happened. The 3 engine mounts are brand new. [/QUOTE] Looking at the picture, I'd say you either damaged the Bush when fitting it, thou I can't see how cos those ones are not tight to fit and a two piece unit. Or, you've got excess movement elsewhere causing extra strain on the top mount?
Post 791986 by Ric@rdo on 2015-11-25 11:05:46
The car went thru a major overhaul last month. All the performance parts listed in my signature and some maintenance parts were all done at once. The engine mounts were also replaced (part of the maintenance parts list) The bush started to brake after the 1st drive. You can see it is this photo that was taken just after the 1st drive. Image What could cause the excess movement?
Post 791990 by jamesy12345 on 2015-11-25 11:32:30
Maybe a daft question but are you sure the new lower mounts were installed correctly, if not the same thing might happen to the new top mount
Post 791991 by Ric@rdo on 2015-11-25 11:35:47
It's a good question :) I'll have a look when installing the new top mount.
Post 792024 by LeeT5 on 2015-11-25 20:35:00
[QUOTE=Ric@rdo;791986] What could cause the excess movement?[/QUOTE] As said, lower mounts ie Transmission torque mount or engine mounts (subframe) worn or otherwise not fitted correctly, will cause excess movement at the top. Too much strain will tear a bush, even poly. If all the lower bushes and mounts are sound then either it was damaged when fitted (poly does tear easily) OR it was a duff bush.
Post 792025 by Ric@rdo on 2015-11-25 20:57:38
I also fitted the poly subframe inserts and the small poly bush in the transmission torque mount. I'm currently away but when I return I'll be having a close look at it and will report back. Cheers!
