Post 789114 by M-R-P on 2015-10-22 22:46:12
Well well well...
I was only asking about this project....
About 2 years ago lol.
No idea what wires you need mate but it's nice to see the project ongoing
Post 789119 by jamesy12345 on 2015-10-22 23:21:30
There's a marked up diagram although a different engine, may be some use
http://www.swededemon.com/images/SD7/shots/ecu/schema-1-signal.jpg
Post 789120 by Dangerous Dave on 2015-10-22 23:32:00
Hope this helps...
Going on the second image with the ecu pins, info for a B5354T7 2009 model with a 30711552 throttle body:
[TABLE]
[TR]
[TH]TB Pin[/TH]
[TH]Control module terminal[/TH]
[TH]Signal type[/TH]
[TH]Ignition on[/TH]
[TH]Idle[/TH]
[TH]Miscellaneous[/TH]
[/TR]
[TR]
[TD]1[/TD]
[TD]A75[/TD]
[TD]Throttle unit motor, control signal (-)[/TD]
[TD]-[/TD]
[TD]PWM signal U top=Ubat Pulse ratio 0-100%. The polarity of the control signal switches when the damper motor is to be deployed in the opposite direction.[/TD]
[TD]The throttle motor is controlled using a PWM signal from the integrated power amplifier in the Engine Control Module (ECM) measured to terminal #A74[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]A14[/TD]
[TD]Throttle position (TP), signal ground[/TD]
[TD]U=Ulow[/TD]
[TD]U=Ulow[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]A19[/TD]
[TD]Throttle position (TP) sensor, power supply 5 V[/TD]
[TD]U=5 V[/TD]
[TD]-[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]A74[/TD]
[TD]Throttle unit motor, control signal (+)[/TD]
[TD]-[/TD]
[TD]The throttle motor is controlled using a PWM signal from the integrated power amplifier in the Engine Control Module (ECM) measured to terminal #A75[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]A88[/TD]
[TD]Throttle position (TP) sensor circuit 2, signal[/TD]
[TD]U≈4-0.4 V[/TD]
[TD]U≈4-0.4 V[/TD]
[TD]The voltage varies depending on the position of the throttle. U decreases with increasing throttle opening.[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]A65[/TD]
[TD]Throttle position (TP) sensor circuit 1, signal[/TD]
[TD]U≈ 0.4-4 V[/TD]
[TD]U≈ 0.4-4 V[/TD]
[TD]U varies depending on the position of the throttle. U increases with increased throttle opening.[/TD]
[/TR]
[/TABLE]
Post 789135 by Dangerous Dave on 2015-10-23 09:46:33
[QUOTE=surrey_100e;789134]That's a great help thanks very much, where did you find that information?[/QUOTE]
Info is from a Volvo tech document.
Lovely project, I like the attention to detail throughout the whole car, everything looks so clean :)
