Washer jets
Post 788621 by Biff on 2015-10-17 19:10:23
Back when I had the fakeR (sigh :() it had washer jets that sprayed a fan of water instead of just a jet. Does anyone know which model they came from? I presume a modern car. Any ideas if they fit my s40 or will I have to bugger about making holes bigger? Looking for cheap effective mods. :)
Post 788622 by martin_r_smith on 2015-10-17 19:15:36
p2 v70 i reckon but not 100%
Post 788624 by foammanmark on 2015-10-17 19:22:43
One of the things that I liked about the Saab that..............
Post 788630 by 500tie on 2015-10-17 19:44:48
I've got them on my V they're from a later C70 but you can buy them from pfv. http://www.partsforvolvosonline.com/product_info.php?cPath=519_547_549&products_id=3187 Don't know if they'd fit your S40 though mate
Post 788652 by Biff on 2015-10-17 21:10:33
If I measure my jets do you mind measuring your c70 ones please? I reckon it wouldn't be a big job so willing to try it. Mark my saab didn't have them, just 3 dual jets. I thought mine was newer.
Post 788662 by The Flying Banana on 2015-10-17 21:36:55
later phase 2 C/S/& V70 had them ...i put them in my 850
Post 788664 by Ettienne on 2015-10-17 21:42:01
[QUOTE=The Flying Banana;788662]later phase 2 C/S/& V70 had them ...i put them in my 850[/QUOTE] Me too
Post 788665 by Biff on 2015-10-17 21:44:19
They make a difference.
Post 788675 by stribo on 2015-10-17 22:54:04
They were fitted to ME7 P1s, fitted some to my pre ME7 C70 having had them on our ME7 S70, so much better. FYI, got some P2 jets for the C70 first, they don't fit, so stick with ME7 P1 ones.
Post 788681 by Kingsford G on 2015-10-17 23:28:53
Just keep a big jug in the car,they never get blocked or frozen lol
Post 788688 by Biff on 2015-10-18 06:30:02
I'm wondering if the p2 ones will fit if the phase 2 p1's don't. Kg I had a Volvic bottle when my pump didn't work on the bullion. 3 points for that you know, driving without due care. I didn't get any though. :)
Post 788690 by 500tie on 2015-10-18 07:43:12
Biff what measurements do you want mate ill do it this afternoon for you? The clips that hold mine into the bonnet have broken so I'm going to be getting a new set in a few weeks, your more than welcome to have the broken ones to trial fit before you spend money on them.
Post 788691 by Blackdog on 2015-10-18 08:27:00
I fitted them to early V70. The irony here is that I got them from a later V40 at the local scrappy.
Post 788693 by Biff on 2015-10-18 09:38:06
Sounding like they will fit or be somewhere near. Thanks boys that's a great help. 500tie that would be great, cheers mate! I'll post my findings should anyone else fancy doing it. Excited by washer jets.. Sometimes it's the simple things. :)
Post 788697 by Kingsford G on 2015-10-18 10:01:16
[QUOTE=Biff;788688]I'm wondering if the p2 ones will fit if the phase 2 p1's don't. Kg I had a Volvic bottle when my pump didn't work on the bullion. 3 points for that you know, driving without due care. I didn't get any though. :)[/QUOTE] Thats what the mrss for lol
Post 788733 by 500tie on 2015-10-18 16:07:53
Right mate the hole that the washer clips into is of a slight oval shape in the bonnet, measuring straight across at the widest point it is approx 12mm. I haven't bothered measuring the bit that sticks on top of the bonnet as that bit doesn't matter. As I said before your more than welcome to my broken ones to trial fit before you buy some once I'm back home in a couple of weeks.
Post 788737 by Biff on 2015-10-18 16:46:21
[QUOTE=500tie;788733]Right mate the hole that the washer clips into is of a slight oval shape in the bonnet, measuring straight across at the widest point it is approx 12mm. I haven't bothered measuring the bit that sticks on top of the bonnet as that bit doesn't matter. As I said before your more than welcome to my broken ones to trial fit before you buy some once I'm back home in a couple of weeks.[/QUOTE] That would be great mate thanks. I have a mini air grinder I can use to oval the holes should needs be so I will make them fit! Cheers mate your a star. Let me know when you have your new ones & I will send you some p&p for them.
Post 788780 by 500tie on 2015-10-18 20:18:57
No probs mate ill let you know
Post 788786 by MoleT-5R on 2015-10-18 21:19:23
Tight ass me removed the v50's washer jets from her, before she went to auction and a ruck of other bits, just trying to decide which car deserves them..???....Gul me thinks :)
Post 788789 by Doingitsideways on 2015-10-18 21:38:02
[QUOTE=MoleT-5R;788786]Tight ass me removed the v50's washer jets from her, before she went to auction and a ruck of other bits, just trying to decide which car deserves them..???....Gul me thinks :)[/QUOTE] I think they'd work well on my S70.
Post 788794 by Biff on 2015-10-18 22:03:43
They are a lot better. The fluid lasted a good while even with my cracked bottle.
Post 788863 by mhon72 on 2015-10-19 17:05:30
I do miss the fan-jet washers I had on my P2. The P3 has the jets but I suspect that's probably to do with the fact they're heated.
Post 788868 by Biff on 2015-10-19 18:23:55
[QUOTE=mhon72;788863]I do miss the fan-jet washers I had on my P2. The P3 has the jets but I suspect that's probably to do with the fact they're heated.[/QUOTE] That's just plain showing off. ;) Good idea though!
