Charging voltage V70 T5
Post 786049 by Orca2 on 2015-09-17 23:30:18
My V70 doesnt seem to be holding battery charge properly, it has failed to start a couple of times over the last week or so, Does anyone know what the voltage should read whilst it is running, ? it reads about 14.1/14.2 volts , and about 12.8 when stopped, Which I would have thought indicates the alternator is healthy, battery was replaced about a year ago. I am suspicious that there is something draining the battery down overnight.
Post 786487 by AAnickmac on 2015-09-22 12:02:29
That sounds right. Have you had the battery checked? Just because it's about a year old doesn't make it good. I would check the battery first. I would also run the engine with a load on (lights, heater blower, rear screen heater ) and see what alternator is then charging at.
Post 789338 by LeeT5 on 2015-10-26 11:28:04
[QUOTE=AAnickmac;786487]That sounds right. Have you had the battery checked? Just because it's about a year old doesn't make it good. I would check the battery first. I would also run the engine with a load on (lights, heater blower, rear screen heater ) and see what alternator is then charging at.[/QUOTE] Sound advice...........Did you get to the bottom of this Orca? Nothing worse than a problem thread.......with no answer at the end! :confused:
