Post 781952 by Blackdog on 2015-08-16 16:48:29
What is it that is in between the outer and inner offside front wing just behind the indicator? Just disconnected the battery and changed the steering wheel and we now have a clicking coming there.
Some frorm of alarm thingy, I removed one whilst stripping the red v70, absolutely no idea what it really does and how it works !!! ??? ;)
It's the alarm . Or the headlight load adjuster or the headlight wash wipe failing But it's most likely the alarm sounder The onboard battery pack leaks into the circuit board after a while.
[QUOTE=Orca2;782040]It's the alarm . Or the headlight load adjuster or the headlight wash wipe failing But it's most likely the alarm sounder The onboard battery pack leaks into the circuit board after a while.[/QUOTE] Thought that was just on the P2?
[QUOTE=MoleT-5R;782017]Some frorm of alarm thingy, I removed one whilst stripping the red v70, absolutely no idea what it really does and how it works !!! ??? ;)[/QUOTE] How do you remove it? Is it a wing off job?
[QUOTE=Blackdog;782097]How do you remove it? Is it a wing off job?[/QUOTE] yep as far as I remember it is a wing off job to remove. I will have a look later as I'm loading the v70 shell to go to the scrappers today
Oops I am referring to P2 the alarm on P2 can be accessed by removing the arch liner.
