V70 Wheel Question: Will they fit?
Post 781164 by petrolh34d on 2015-08-10 15:12:09
I've got a 1997 V70 2.5 TDi, currently wearing these:
Shod in 205/55/16
[ATTACH=CONFIG]29415[/ATTACH]
Looking at a set of these of a 2005 C70:
Shod in 225/45/17
[ATTACH=CONFIG]29416[/ATTACH]
Will they clear my arches?
Post 781165 by petrolh34d on 2015-08-10 15:25:58
I think this is what I'm looking at?
[ATTACH=CONFIG]29417[/ATTACH]
Post 781166 by SmudgeLikeInk on 2015-08-10 15:30:45
I would say so yes, They wont protrude any further out than your current wheels, the extra width will make them closer to your suspension springs, but still should be enough gap without any problems. The extra inch wheel, but smaller tyre wall will probably make the car have a similar arch gap to what you currently have. I had 225/55/17 and now have 225/45/18 and the cap is more or less the exact same.
hope this helps.
Post 781168 by stephenevans99 on 2015-08-10 15:46:20
I'm certain the Comet wheels will fit without issue.....also the Comets came in two widths: V70R Comets were 7.0J whilst the C70 Comets were 7.5J
Post 781169 by petrolh34d on 2015-08-10 15:49:48
Cheers guys, that's a big help!
Post 781173 by Biff on 2015-08-10 16:16:42
Straight on no worries. ;)
Post 781186 by Blackdog on 2015-08-10 18:37:43
Running 225/45/17 comets on our TDi.
All they do is rub on the front on full lock.
Post 781194 by martin_r_smith on 2015-08-10 19:09:21
I use 225/45/17 on comets on my tdi too, I stopped the full lock rub with thicker steering stops.
Post 781202 by 500tie on 2015-08-10 19:31:54
I'm the same as Martin r smith, i just put C70 lock stops on the front lower arms no rubbing now. I did however need to put 5mm spacers on the rear as it started to eat through my arch linings.
Post 781206 by Blackdog on 2015-08-10 19:47:19
[QUOTE=500tie;781202]I'm the same as Martin r smith, i just put C70 lock stops on the front lower arms no rubbing now. I did however need to put 5mm spacers on the rear as it started to eat through my arch linings.[/QUOTE]
Are you running standard ride height?
I ask as we have no signs of rear rubbing.
Post 781227 by 500tie on 2015-08-10 21:21:36
Blackdog, yep standard ride height tyres are pretty new though continental sport contact 3's if that makes a difference. I know the guys who run AWD's have rubbing issues on the rear but I don't know if there any others like me running an FWD with the rears rubbing. It mostly rubbed on the inside of the tyre on the bolts that hold all the inner arch to the metal.
Post 781228 by AcidicDavey on 2015-08-10 21:23:15
Sooty, you're running P2 wheels so they are 6mm more offset hence the need for spacers on your car as they are 6mm more set in to the arches :)
I had C70 Comets on my car too and no rubbing to report ;)
Post 781231 by 500tie on 2015-08-10 21:39:32
Excellent point Dave I knew you would know the answer why mine rubbed mate
Post 781242 by AcidicDavey on 2015-08-10 22:15:36
Sooty, the ONE thing I know is wheels lol
Post 784303 by petrolh34d on 2015-09-02 14:14:52
The guy that was selling the Comets fecked about, and decided not to sell the wheels in the end, so I've had to go for a different set, which my mates and I just finished refurbing last night.
They are 7.5j 18" et:52.5, and I'm planning to get 225 18 40 tyres for them.
Am I correct in saying that I'm going to need at least 15mm spacers to get practical clearance?
Can someone recommend where to get a good set of spacers?
Post 784330 by AcidicDavey on 2015-09-02 19:01:58
10mm spacers will get you to the standard fitment anything more will space them out more than standard so yes 15mm will be spot on.
Custom hubcentric spacers are available from http://www.superforma.co.uk/
I've used them myself for my PCD Adaptors, perfect!
10% off with discount code 10DISC ;)
Post 784468 by petrolh34d on 2015-09-03 11:54:12
Cheers Davey.
There's a 10 day waiting period on Superforma, and it'll put 10 years on me if I have to wait that long lol.
After much, much searching, I ordered these instead: http://www.ebay.co.uk/itm/170767470574?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
(Still won't be here until Monday though :sorry: )
Is there such a thing as lengthened locking wheel nuts?
Post 784489 by AcidicDavey on 2015-09-03 18:20:06
What wheels are you putting on?
And yeah, you will want extended wheel bolts really.
There are a few different sizes on eBay, maybe the ones with the 40mm thread?
Post 784578 by petrolh34d on 2015-09-04 09:46:37
[QUOTE=AcidicDavey;784489]What wheels are you putting on?
There are a few different sizes on eBay, maybe the ones with the 40mm thread?[/QUOTE]
I wanna keep it secret until they're actually on dude.
Thankfully the spacer kit is supplied with lengthened bolts. I'll probably just modify some of them into locking nuts.
Post 786381 by petrolh34d on 2015-09-21 14:13:30
The saga with getting my new wheels fitted continues. I'm encountering issues with every single thing I do :cussing:
Most recent hiccup is that I've had to re-order spacers, as the first ones were supplied with post 2000 Volvo studs, now the new set I've order from Italy have been supplied with fecking Ford studs. Messaged seller, but still no reply (what's the bets this is going to be a handling to get sorted?)
After I get the wheels fitted, I'm gonna be looking a set of 40mm lowering springs for her.
I'm looking on eBay, and the main spring types are coming up as Kilen, Direnza and Eibach, with prices varying from about £100 for Kilens, up to about £250 for Eibachs.
What could I expect to find different between the different brands of springs?
Post 788175 by petrolh34d on 2015-10-12 21:30:06
Wheels + tyres acquired, spacers acquired, extended wheel bolts acquired.
Now I need washers to convert the 60° bolts to flat faced Jaguar style nuts, which have an 18.5mm diameter shank seen here in figure A.
[ATTACH=CONFIG]29812[/ATTACH]
I'm looking at these Peugeot conversion washers, which as far as my research tells me, only have a 17mm diameter shank, but they are the closest that I can find.
[ATTACH=CONFIG]29813[/ATTACH]
Will they do the job, or can anyone advise me what to do here, as getting these wheels on is taking years off me lol.
Post 788987 by disco on 2015-10-20 19:20:45
Hi there just put on 225 45 16 toyos on the original persus wheels you started with and have aready dropped t by 40 mm looks and rides soo much better sorry havent got a picy yet but camera still not talking to computer dave
Post 789351 by petrolh34d on 2015-10-26 13:42:03
Cheers Dave, that's encouraging.
Ok, wasn't going to put any pictures up until I actually had the car lowered, but would like some opinions now before I actually proceed with that.
The car is my daily, and I carry very big loads pretty regularly. Should I stick with standard ride height, or can I consider a drop?
Here's two bad snaps of how she sits currently.
[ATTACH=CONFIG]29890[/ATTACH]
[ATTACH=CONFIG]29889[/ATTACH]
Post 789353 by Biff on 2015-10-26 14:14:45
[QUOTE=petrolh34d;789351]Cheers Dave, that's encouraging.
[ATTACH=CONFIG]29889[/ATTACH][/QUOTE]
I wouldn't of said a drop was on the cards really, not a lot of room in those arches.
