glass cutting compound
Post 780788 by t5 pete on 2015-08-07 22:09:40
On the other half's s70r it looks like some one has used grit sand wiper blades as the entire stroke of them is full of light scratches personally ide like to keep the original screen so Can any one recommend a decent cutting compound for the entire windscreen? I've seen the kits on ebay but they are only tiny cutting pads and would take forever. Or is it a case of just get a new screen fitted.
Post 780792 by Blackdog on 2015-08-07 22:21:22
Have you got a DA machine?
Post 780794 by t5 pete on 2015-08-07 22:25:39
Hello yes I've got a machine polisher I did give it a going over with g3 which has improved it slightly
Post 780795 by Blackdog on 2015-08-07 22:30:30
I will find it in the morning and post up but its something that was recommended on here and it is bloody great. Used it on the Mrs 98 V70 and will be doing my 14 V70 this weekend.
Post 780796 by deathrider311271 on 2015-08-07 22:38:53
the stuff you want is Jewellers rouge mate
Post 780799 by t5 pete on 2015-08-07 22:46:13
[QUOTE=deathrider311271;780796]the stuff you want is Jewellers rouge mate[/QUOTE] Cheers bud is it this stuff http://www.ebay.co.uk/itm/GOLD-AND-SILVER-JEWELLERS-ROUGE-GLASS-SCRATCH-REMOVER-WITH-POLISHING-BOB-/110983204941?pt=LH_DefaultDomain_3&hash=item19d71d504d
Post 780800 by MIKESC70T5 on 2015-08-07 22:48:20
I've used this stuff with good results CarPro CeriGlass polish kit.
Post 780802 by Blackdog on 2015-08-07 22:52:33
This is the stuff I was talking about http://www.cleanyourcar.co.uk/engine-and-exterior/glass-cleaners-sealants/carpro-ceri-glass-kit/prod_988.html Mike beat me to it
Post 780806 by stribo on 2015-08-07 23:41:48
Great info, my C70's windscreen looks like it's been sand blasted, owing to its age, but has no chips or cracks , so, that's probably my best bet.
Post 780878 by deathrider311271 on 2015-08-08 19:36:38
[QUOTE=t5 pete;780799]Cheers bud is it this stuff http://www.ebay.co.uk/itm/GOLD-AND-SILVER-JEWELLERS-ROUGE-GLASS-SCRATCH-REMOVER-WITH-POLISHING-BOB-/110983204941?pt=LH_DefaultDomain_3&hash=item19d71d504d[/QUOTE] yep thats the stuff Pete, we used it all the time when i was in Jewellery business, does exactly what it says gets scratches out of glass
Post 781129 by Kingsford G on 2015-08-09 22:59:29
Have to try this one.
Post 781132 by Orca2 on 2015-08-09 23:04:09
Cerium oxide .. If you can get your hands on some, cuts and repolishes glass .
Post 806844 by Squirtydog on 2016-11-03 07:01:10
I could do with this for the new car. Quite a few very superficial looking scratches. I have read warnings about 'lensing' the glass. Does anyone have experience of this, or how to avoid it in amateur hands? Because of this I was planning on finding a professional to do it.
Post 806851 by Gold 'N' Brown on 2016-11-03 11:52:10
For the sake of balance I'll add that I tried the same stuff Mike mentioned above using my DA and a glass cutting pad, and to be honest I noticed little if any improvement, and that was with several hours work on just part of the screen (I never bothered finishing the screen as it seemed futile). It seems to work for some so I'd guess that the model of car must be a factor (although I would have thought the "toughness" of the screen should be fairly much a constant regardless of car, unlike the paint), as well as how bad/deep the scratches are. I even checked a Youtube tutorial half way through to make sure I wasn't doing it wrong - fella was using the exact same product and you could see the improvement on his screen.
Post 806875 by jdavis on 2016-11-03 20:39:55
I'll have to try this on mine
