Post 780323 by The Thong on 2015-08-04 19:44:07
On my V50 I have 2 bent rims. I've got 17" Zurak wheels which are proving hard to come by. So.... I'm thinking of looking at alternatives. Here's my car
And these are the wheels I'm thinking of fitting
So, do you think it'll look great on my motor and do you think they'll fit?
TT
Post 780324 by twr on 2015-08-04 19:46:35
What's the et etc on the new rims?
Post 780328 by Orca2 on 2015-08-04 20:03:24
Get someone to photoshop them onto the car , where is Liberate when you need him ?
They look like nice wheels mate , the Rashermobile will suit them.
Post 780332 by The Thong on 2015-08-04 20:09:43
Yeah, Liberate would have been the man for that job.... It'd certainly make it easier to decide Orca
Post 780333 by The Thong on 2015-08-04 20:13:47
[QUOTE=twr;780324]What's the et etc on the new rims?[/QUOTE]
Don't know what you mean
Post 780337 by Harvey on 2015-08-04 20:31:11
Any wheel that has a clear coat Finish on alu will start to corrode from the edge in , just a thought.
PS they are smart looking rims..
Post 780338 by AcidicDavey on 2015-08-04 20:34:38
[QUOTE=The Thong;780333]Don't know what you mean[/QUOTE]
What is the width and offset of the wheels you have your eyes on, you need to compare to your current wheels so you'll know how set into the arches the wheels are ;)
Post 780367 by The Thong on 2015-08-04 22:38:19
If I've got this right, the tyre size is the same but my current offset is 45mm the 17" Ixiom rims are 50mm. I'm still trying to nail down the stud spacing and stud size
TT
Post 780372 by AcidicDavey on 2015-08-04 22:48:12
The stud pattern will be the same, 5x108.
So with that difference in offset the wheels will be set into the arches 5mm more than your existing wheels ;) (assuming they are the same width).
Post 780374 by Orca2 on 2015-08-04 22:50:21
Harvey made a good point about clear lacquered alloys, they can be a beehatch to keep, the slightest pin£££££ leads to the dreaded " alloy worm tracks " creeping across the surface.
Post 780393 by S40kieran on 2015-08-04 23:39:11
Nice wheels thong should be loads of options open to you ford fitment aswell don't forget ;)
Post 780395 by AcidicDavey on 2015-08-04 23:43:26
Found this photo of a normal V50 with 17 inch Ixions, looks good.
[ATTACH=CONFIG]29391[/ATTACH]
Post 780396 by Orca2 on 2015-08-04 23:45:49
They look great, it looks like its moving when its standing still.
Buy them Thongster, the Church of The Lard compels you.
Post 780403 by The Thong on 2015-08-05 06:51:28
That sorts that then, they fit. I'll keep scratch eye out now
TT
Post 780404 by MoleT-5R on 2015-08-05 07:08:25
I may have a full set of your original wheel that may be available, just need to check and I'll let you know if your interested
Post 780410 by The Thong on 2015-08-05 07:46:46
Ok, let me know. I'm assuming they're straight? Sorry, gotta ask.
TT
Post 780469 by The Thong on 2015-08-05 17:47:01
[QUOTE=AcidicDavey;780372]The stud pattern will be the same, 5x108.
So with that difference in offset the wheels will be set into the arches 5mm more than your existing wheels ;) (assuming they are the same width).[/QUOTE]
Tyre size is the same... It's looking optimistic
TT
Post 780478 by AcidicDavey on 2015-08-05 18:44:27
Even if they didn't you could make them fit :P
Worst case scenario is you'll need 5mm spacers but I highly doubt they'll be necessary!
Post 780505 by The Thong on 2015-08-05 19:29:30
Judging by the picture of the V50 above its not going to be a problem. The tyre size matches, I had a shufty at a V40 while I was at the dealers today. I'm confident
But.... If a set of Zurak's come up then I'll stick to the original spec
TT
Post 780568 by M-R-P on 2015-08-06 00:32:14
Ixion is the name and by far the best looking Volvo wheel imo. They'd look superb on your car mate.
Post 780591 by kmb on 2015-08-06 08:54:44
Try this website when comparing wheel sizes, offset etc:
http://www.willtheyfit.com/
Post 780714 by MoleT-5R on 2015-08-07 05:06:40
[QUOTE=The Thong;780410]Ok, let me know. I'm assuming they're straight? Sorry, gotta ask.
TT[/QUOTE]
as far as I'm aware they are, but will check at the this weekend and get back to you.
