Bulb related stupid question
Post 779717 by 500tie on 2015-07-30 19:44:12
Does anyone know what the correct bulbs are for the brake light and indicators on the rear of a 1997 V70. Some places say they're Ba15s Some say 382's Some say 581's I'm bloody confused to say the least and knowing my luck I'll end up buying completely the wrong ones.
Post 779723 by The Flying Moose on 2015-07-30 20:11:27
Im 95% they are 382's sadly however I dont have a manual anymore. Your owners book should tell you too.
Post 779758 by Dangerous Dave on 2015-07-30 23:20:10
I'll have to pop out and check what mine are (same car), but it won't be until tomorrow morning I'm afraid.
Post 779777 by 500tie on 2015-07-31 06:04:59
[QUOTE=Dangerous Dave;779758]I'll have to pop out and check what mine are (same car), but it won't be until tomorrow morning I'm afraid.[/QUOTE] That's not a problem I'm not in a rush thanks for that and in the mean time I'll have a flick through my owners manual see what it says in there
Post 779791 by Spooky on 2015-07-31 09:36:01
i bought one for mine the other day... not sure what the number was, but it was a single filament if that helps?
Post 779796 by Dangerous Dave on 2015-07-31 10:29:10
Just popped out and had a look. Here's a breakdown from the top (various codes for the same bulb): Top Cluster: Indicator - PY21W or 581 - Single contact, has offset locking pins and has an orange bulb coating as the indicator lens is clear Brake - P21W or 382 - Standard single contact Bottom Cluster: Side and (?) - P21/4W or 566 - Dual contacts, has offset and staggered locking pins (think only the 4W part is used as there was only one contact in the bulb holder, odd really) Reverse - P21W or 382 - same as above Side and Fog - P21/4W or 566 - same as above Hope this helps
Post 779821 by 500tie on 2015-07-31 15:16:52
[QUOTE=Dangerous Dave;779796]Just popped out and had a look. Here's a breakdown from the top (various codes for the same bulb): Top Cluster: Indicator - PY21W or 581 - Single contact, has offset locking pins and has an orange bulb coating as the indicator lens is clear Brake - P21W or 382 - Standard single contact Bottom Cluster: Side and (?) - P21/4W or 566 - Dual contacts, has offset and staggered locking pins (think only the 4W part is used as there was only one contact in the bulb holder, odd really) Reverse - P21W or 382 - same as above Side and Fog - P21/4W or 566 - same as above Hope this helps[/QUOTE] Dave that helped immensely thank you very much and I think the one that you said was side and? Is that not the an emergency back up light and side light from what I remember in the manual
Post 779877 by Dangerous Dave on 2015-07-31 23:04:24
No worries mate, thats what we're here for. I'll have to get my book out and have a look at what that one is.
