Just how good are machine polishers?
Post 779405 by Doingitsideways on 2015-07-28 17:30:08
As above. Will they buff these arches up? Image :lol:
Post 779406 by M-R-P on 2015-07-28 18:06:34
You'd be better off using a hiab... ... To lift it into a skip :)
Post 779407 by Doingitsideways on 2015-07-28 18:10:50
That where yours has gone? That why you've not been on here much? :lol:
Post 779410 by Tomcat on 2015-07-28 18:43:55
Christ I wish that ££££ would buff out.
Post 779412 by 500tie on 2015-07-28 18:50:09
Wheeler dealers would be able to get them to buff out
Post 779419 by Doingitsideways on 2015-07-28 19:50:05
[QUOTE=500tie;779412]Wheeler dealers would be able to get them to buff out[/QUOTE] Aye, Ed China's a wonder with them!
Post 779421 by Doingitsideways on 2015-07-28 19:51:15
[QUOTE=Tomcat;779410]Christ I wish that ££££ would buff out.[/QUOTE] You just wish it would buff off your drive!
Post 779423 by jamesy12345 on 2015-07-28 20:03:41
can u do these also.... [ATTACH=CONFIG]29376[/ATTACH] [ATTACH=CONFIG]29377[/ATTACH] needs an engine too
Post 779424 by Tomcat on 2015-07-28 20:23:50
Nice, though I'm not sure a buffing alone can replace an engine.
Post 779425 by Doingitsideways on 2015-07-28 20:24:26
[QUOTE=jamesy12345;779423]can u do these also.... [ATTACH=CONFIG]29376[/ATTACH] [ATTACH=CONFIG]29377[/ATTACH] needs an engine too[/QUOTE] Easy. Craig'll sort them ;) I know a blue 480 with an engine that would fit.
Post 779426 by Tomcat on 2015-07-28 20:25:03
:yikes::yikes:Oi!!, stop volunteering me!! lol
Post 779428 by AcidicDavey on 2015-07-28 20:39:05
T cut is what you want boys, amazing stuff (apparently).
Post 779432 by Saaamon on 2015-07-28 20:49:50
Afternoon with some touch up paint and that would look magnificent.
Post 779433 by Doingitsideways on 2015-07-28 20:50:24
Post 779436 by Doingitsideways on 2015-07-28 21:00:20
[QUOTE=Tomcat;779426]:yikes::yikes:Oi!!, stop volunteering me!! lol[/QUOTE] I'm like your pimp! ;)
Post 779464 by M-R-P on 2015-07-28 23:32:39
[QUOTE=Doingitsideways;779407]That where yours has gone? That why you've not been on here much? :lol:[/QUOTE] Find any rust on mine Steve and I'll fix the rust on yours :)
Post 779467 by Doingitsideways on 2015-07-29 00:02:18
Hmm... Sounds like a challenge to me!
Post 779468 by M-R-P on 2015-07-29 00:11:28
[QUOTE=Doingitsideways;779467]Hmm... Sounds like a challenge to me![/QUOTE] Aluminium bonnet... plastic tailgate... Vinyl wrapped roof... half a ton of paint on everything else... good luck :D
Post 779469 by Tomcat on 2015-07-29 00:13:35
Hehehehe... You've not mentioned the mechanicals underneath..
Post 779470 by M-R-P on 2015-07-29 00:16:19
[QUOTE=Tomcat;779469]Hehehehe... You've not mentioned the mechanicals underneath..[/QUOTE] The ones I've spent the last 5 1/2 years replacing? Clean as mate :)
Post 779471 by Tomcat on 2015-07-29 00:23:41
Damn...lol..
Post 779472 by t5 pete on 2015-07-29 00:27:09
Bit of chicken wire and some dry wall adhesive will do the trick in fact bugger the chicken wire some scrim tape will do just fine
Post 779473 by Doingitsideways on 2015-07-29 01:07:53
Balls to that. The rate it rusts my trowels if I don't clean them, they'll be worse than they were to start with! Martin: My money's on number plate screws, even if they are under caps. Better get mixing your filler, Mate!
Post 779474 by Doingitsideways on 2015-07-29 01:10:57
Only posted as a joke. Turned out to be the hot topic of discussion... At one in the morning! Lol Image
Post 779475 by AcidicDavey on 2015-07-29 01:14:17
Says a lot about this place I think Steve :P
Post 779476 by M-R-P on 2015-07-29 01:17:12
Sod all else going on :)
Post 779496 by Tomcat on 2015-07-29 10:22:54
How very true
Post 779615 by RichT4 on 2015-07-30 07:34:33
[QUOTE=Doingitsideways;779467]Hmm... Sounds like a challenge to me![/QUOTE] You'll find some in behind the wheel arch liners, under the chassis and behind the engine on the bulkhead ;)
Post 779627 by M-R-P on 2015-07-30 10:05:33
[QUOTE=RichT4;779615]You'll find some in behind the wheel arch liners, under the chassis and behind the engine on the bulkhead ;)[/QUOTE] Feel free to have look mate ;) I think some of the brake pipe brackets have a little surface corrosion but I don't call that rust.
