Post 776799 by TenaciousC on 2015-06-25 18:33:55
Something oil cooler related has gone spectacularly wrong!
Oil pressure light, smoke, and there is a huge puddle of oil under the front of the car. The AA man cometh! Engine was running OK at shutdown, so hopefully no serious damage done! (Just a bloody mess).
C
Post 776800 by stribo on 2015-06-25 18:43:51
Had the same happen to our V70R, luckily Shem was driving it at the time, at stopped it immediately, had no problems once a new rad was fitted.
Post 776803 by Ettienne on 2015-06-25 19:58:49
My oil cooler on the gul is weird, it's new and done less than 1,000 miles and not been fitted by me and the rest of the car was a joke the work on it.
Anyhow I get literally one drip from the car after it's been used, I tend to think its oil thermostat housing or lines (o-rings).
No mixing of the oil and water etc.
I tend to think it's how it's been fitted, but it's so small I can't track it down, I may just use it a bit and see what happens as it's been laid up for 3 years.
Post 776804 by stribo on 2015-06-25 20:18:23
[QUOTE=Ettienne;776803]My oil cooler on the gul is weird, it's new and done less than 1,000 miles and not been fitted by me and the rest of the car was a joke the work on it.
I tend to think it's how it's been fitted, but it's so small I can't track it down, I may just use it a bit and see what happens as it's been laid up for 3 years.[/QUOTE]
Check the clips on the oil cooler.
Post 776805 by Ettienne on 2015-06-25 20:24:49
Yep did all that (as you'd expect) first thought was clips, o-rings or therm housing, but it's so small it's not obvious.
I suppose it could be a split pipe, but it would be the first I've had.
I'll give it a drive and see.
Post 776806 by TenaciousC on 2015-06-25 20:25:06
It was one of my home brew cooler lines. The hose clamp I used wasn't quite tight enough and the line must have slid off the metal connector. I'll need to amend the howto guide. How embarrassing!
The AA man was a top guy and had an appropriate jubilee clip.
C
Post 776810 by Ettienne on 2015-06-25 21:17:02
[QUOTE=TenaciousC;776806]It was one of my home brew cooler lines. The hose clamp I used wasn't quite tight enough and the line must have slid off the metal connector. I'll need to amend the howto guide. How embarrassing!
C[/QUOTE]
Ironic I was just saying that lol.
Just been out in the gul and nothing, I'll just keep an eye on it.
