can anyone give me a rough idea please?
Post 776090 by no1tosh on 2015-06-16 18:46:20
hey can anyone give a rough idea at what sort of cost it would be to get a 740 or 940 to lets say 250-275 bhp or 300 bhp at a push iv'e always fancyed a black 740 estate sleeper. ive read a few threads on turbo bricks, the staged tuning guide and also the guide they had in PPC mag a few years back. i know there's a lot of factors like how much you can find bits for ect... i just want to see if im in the same ball park. PPC recons it can cost as little as £500 plus the car to get 250-300 bhp. Im struggling to belive that tbh. cheers
Post 776105 by t5 pete on 2015-06-16 19:32:55
Ide say a clocked 19t injectors and othwr bits and bibs with chips would see 250
Post 776108 by no1tosh on 2015-06-16 19:58:02
clocked????
Post 776109 by kmb on 2015-06-16 20:00:00
Chipped ECU or MBC, I think he means running a turbo with more boost than originally intended...
Post 776111 by t5 pete on 2015-06-16 20:03:28
Nope you need to turn the turbo 180 degrees if you search good it will give you a how to
Post 776112 by Doingitsideways on 2015-06-16 20:04:00
He means the turbo turned around to face the right way, as required in fitting a 19t to a 940. ;) Edit: Damn, beat me to it Pete!
Post 776134 by no1tosh on 2015-06-16 21:13:11
ahhhhhh i see, all becomes clear lol. so i take it that ppc mag saying you can get 250 300 bhp for £500 ish is a pile of crap? i though it was to good to be true. i think this is where the got there base info from: http://strikeengine.com/volvo-parts-tuning/volvo-700-900-turbo-tuning-guide.html cheers
Post 776153 by the young mechanic on 2015-06-16 22:26:41
ide say bout 750
Post 776155 by t5 pete on 2015-06-16 22:32:55
Factor in costs 19t/18t 300 Exhaust 300 Injectors 60 Gold box and chips 150 Then you also need to start thinking about the clutch and the gear box unless you get a late 940 Next problem is then the open diff then the handling then the braking to do it right your into 2k. No point having a old car running 300hp when it's suspension cannot handle in and you cannot put the power down
Post 776157 by Ettienne on 2015-06-16 22:41:12
A big tick to most of the above on mine :)
Post 776217 by no1tosh on 2015-06-17 19:57:16
Iill give that a miss then, cant afford that lol. Cheers for the replys lads
Post 776843 by c70geoff on 2015-06-26 12:19:59
as ive found its easier and cheaper to buy and play with an 855 t5
Post 776873 by smithy on 2015-06-26 19:33:08
Bigger turbo ,exhaust ,3in maf,big filter,bigger injectors 470cc job done .300 bhp no probs then the clutch won't take it lol.
Post 776874 by smithy on 2015-06-26 19:35:29
Standard turbo is good for 220 max but makes a quick car .get an early 15g and fit that with ether chips or bigger maf and 470cc injectors job done 250bhp easy .clutch will just about hold
Post 777621 by no1tosh on 2015-07-05 13:47:47
That's what I was kind of thinking that, I've got an 855 R manual and don't get me wrong I love it but I just love the look of the older ones! Oh and the fact it's rear wheel drive.
